I have a serious question
Old Jan 10, 2013 | 08:28 PM
EuroGirl's Avatar
Ok before I tell you I want to say this problem happens randomly and only when I start the car up. Basically my car revs up and down fairly quickly by about 500rpm. After like 30sec. To a minute it idles normally and runs fine. Though what's causing this? It sounds like my car has monstersously huge cams in it randomly!
Old Jan 11, 2013 | 01:10 AM
Black03Mach1's Avatar
I had a cracked vacuum hose that caused mine to do that, it's a pretty easy fix
Old Jan 11, 2013 | 11:21 AM
skunk21's Avatar
vacuum leak like stated also possible iac sticking.
Old Jan 11, 2013 | 08:46 PM
Aussie Cobra's Avatar
Yeah, sounds like a split vacuum hose, I had that problem last year. Check the ends of all the hoses under the hood, if the split isn't too long you may be able to cut the hose shorter.
Old Jan 11, 2013 | 09:44 PM
vacuum hose should be your fix
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
