How to unplug the amp connections on back of Radio
Old Aug 19, 2005 | 05:06 PM
2000gTstang's Avatar
I have managed to unlug every connection on the back of the Radio except for the Black AMP plug on the top right of the radio. How do you unplug this one? just pull on it hard?
And to take the cd player out do you have to push the DIN tools to the inside or outside cause I cant seem to get it out?
Old Aug 19, 2005 | 05:08 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
usually plugs have a small button in the middle of the latch part you can press down. Its been awhile so I cant remember that plug exactly.
If you are using the OE ford removal tools, they should just slide in both holes, then put some pressure to the outside edge of the radio and pull. It should somewhat "catch" in there and allow you to pull it out. May have to try applying pressure inside as well to see if that works.
Old Aug 19, 2005 | 05:19 PM
OK thanks, My friend and I are using metal coat hangers to take it out.
Old Aug 19, 2005 | 09:42 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Go to wal-mart, buy the tools. it will be much easier.
missc1115
Aug 26, 2015 07:56 AM
Lake_Vert
Aug 11, 2015 06:40 AM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
nismos13s14
1994-2004 V-8
Jul 31, 2015 12:55 PM
K.A.I.N
Jul 20, 2015 06:42 AM
