Hey!
Old Jan 9, 2011 | 09:03 PM
Hawaii 5.0's Avatar
Hey!
Ok guys i just found two engines i could get some sweet deals on. I can a new 5.0 engine and drop that in my 02 GT (tranny and everything else i need) for about $6,500. Or i can a 351 engine and the new tremec 6 speed for about $8,000 (supporting parts included) what would yall say? I know its gonna be a pain in the *** to drop em in but ive been wantin to do this for a while.
Old Jan 10, 2011 | 03:35 AM
cntchds's Avatar
The new 5.0(OHC), or a new 5.0(OHV)?
If the questions is about the new OHC 5.0 then I say go with that in a heart beat. The computer you have obviously won't work with it, but the motor mounts are the same as the 4.6 IIRC. That in itself takes a load of the work out, because at least then you can kind of have a starting place. Not to mention the power and torque of the new motor, plus the efficiency of variable valve timing. It's a win win.
If the question is 302 or 351, I'm not really sure what to say, because I can't imagine a reason you'd want to go back to stone age tech like that.
Old Jan 10, 2011 | 02:35 PM
Hawaii 5.0's Avatar
Wella buddy of mine has a 351 block in his car and its puttin up some real good numbers. But yea the OHC is definitely wjat im leaning for, i was mainly looking as to what other people would say here
Old Jan 10, 2011 | 04:35 PM
cntchds's Avatar
There is no doubt that the 351 will put down good numbers, but I can't imagine the power would outweigh the weight savings of an all aluminum motor. If your car was a 94-95 I would probably have a different thought, but I just don't see a point in transplanting an older motor.
Old Jan 10, 2011 | 05:12 PM
Hawaii 5.0's Avatar
Yea i see whatyour sayin. Plus the new aluminum is a dual overhead so higher and quicker revs so its much faster into the power band as well
Old Jan 12, 2011 | 09:09 AM
Miserable's Avatar
That's an incredible deal for the new 5.0 and trans. There's no way I would pass that up. Going to need the new ECU and probably will have to get headers made and replace the K-member and some of the fuel system but if you can get the engine and trans for under 7K, you should go for it.
Old Jan 12, 2011 | 04:07 PM
Hawaii 5.0's Avatar
Yea, its just gonna be a real pain gettin that 302 in the bay. Prolly gonna try and get the new ecu and fuel system in when things warm up a bit. Im not sure which headers im gonna gp with but im gonna be hookin em up to a spintech shstem cuz ill be gettin a roush kit sometime before the summer. Ill definitely post pics of the build process once it gets going
Infamous_blackbeard
Oct 8, 2015 10:45 PM
MustangConvert11
Sep 30, 2015 08:01 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
