help with 95 gt
help with 95 gt
I have a 95 gt and im doing some topend mods so far I have a set of x302 heads b303 cam frpp lifters roller rockers underdrive pulleys and a smog pump delete. I need some advice on what upper lower intake to get tb maf and injectors taking all suggestions
24lb injectors, 75mm maf, 70mm TB and just about any good aftermarket intake from trickflow, holley, etc. stay away fro the "R" and box type intakes for your set up and get a tune. my reason to tune: even though the aftermarket sells a 'scaled' or 'skewed' maf/samle tube to trick the ecm when using a different size injector sometimes there can be driveability issues, etc. where as when a proper tune is done you get an ecm recalibration, done. End of guess work.
