Help
Old 6/8/07 | 07:18 AM
kingC95GT's Avatar
Help
i want to get a new cam. i have a E cam, but i was looking into a lunati or a stage one trick flow. i have twisted wedge heads and i was wanting help on which one to get, and not have clearance problems. thanks
Old 6/8/07 | 01:27 PM
Scothew's Avatar
Stubborn Bear
TMS Staff
Stage one from trick flow I would think is designed around thier heads and would be a sure enough to not have clearence problems. You may want to call summit and talk to thier advisors as they have specs on almost all parts available on hand to work with you.
Old 7/2/07 | 05:49 AM
bluethunderhorse's Avatar
I have the trickflow stage 2 cam and I didn't have any clearance problems so I know the stage one won't these are the specs on the stage 1
Basic Operating RPM Range:2,000-5,500
Intake Duration at 050 inch Lift:221Exhaust Duration at 050 inch Lift:225Advertised Intake Duration:275Advertised Exhaust Duration:279Intake Valve Lift with Factory Rocker Arm Ratio:0.499 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.510 in.Lobe Separation (degrees):112
