Havnt posted in awhile but need help
Originally Posted by sinisterbullitt
It will flow more air yes. Especially if you do the intake too. On a stock motor? This include valves and everything
Do a Pi swap. It's good for about 70 hp. I have all the necessary parts if you want em. Heads,Pi intake,tb and plenum and fuel rails. If your gonna pull the heads anyway to port em forget doing all that work and just bolt on my heads. I am camming a pair of windsors then swapping my heads for the cammed ones. I only have 80k on the originals and I was gonna keep em around but I will let you have it all if you want it. Everything is still on the car right now. I will be pulling it apart next weekend or sooner if the cams show up
The intake would help yes. But Everett has a good point and I'm sure it'd be a lot less with his parts. Massaging the heads and intake is $$
