gears
Old Feb 20, 2013 | 04:41 PM
stephenjoz's Avatar
gears
What gears are better 3.73 or 3.55?
Old Feb 20, 2013 | 04:49 PM
skunk21's Avatar
They are really close, the 3.55s have a few less rpm at cruising than the 3.73s. Really if you drove a car with 3.73s long enough you really wouldn't feel the difference between them. for what its worth I run 3.73s. either are good imo.
Old Feb 20, 2013 | 04:54 PM
stephenjoz's Avatar
Ok are 24lb injectors worth it for a mildly modded car
Old Feb 20, 2013 | 05:02 PM
skunk21's Avatar
need more info. what year, motor and mods. ie heads are they stock or aftermarket, cam etc.
Old Feb 20, 2013 | 05:11 PM
stephenjoz's Avatar
95 x302 heads b303 cam bbk tb75mm tfs streetburner intake
stephenjoz's Avatar
Mac shorty headers
Old Feb 20, 2013 | 05:16 PM
skunk21's Avatar
with those mods you need to be running atleast 24s and a tune. are you still running the stock fuel pump?
Old Feb 20, 2013 | 05:43 PM
stephenjoz's Avatar
Havent put car together all parts are still in boxes and I have not even looked into fuel pumps
Old Feb 20, 2013 | 05:59 PM
skunk21's Avatar
255lph pump, 75mm maf, 24lb injectors and a tune. The maf will come with a calibration but there can be driveability issues, keep in mind the aftermarket sells a 'scaled' or 'skewed' maf/samle tube to trick the ecm when using a different size injector. IMO the best option is to have a proper tune, ecm recalibration, no guessing... done.
Rando
Aug 25, 2021 11:12 AM
AMAlexLazarus
Oct 15, 2015 11:06 PM
Rando
Sep 30, 2015 12:28 PM
Airborne42
Sep 24, 2015 10:27 AM
