Gasket replacement or new intake
My 2000 gt has a coolant leak I found a puddle just in the middle of the block and it seems that leak come from the thermostat housing, do I need a new intake or just a gasket replacement?
Originally Posted by 96gt014.6
If you can't see anything at all with the intake like a crack or anything then just a gasket. But check for cracks to make sure before just get a new gasket
Originally Posted by jbond0220
Is pull the intake off and check it thoroughly for cracks. Plastic intake manifolds on these are horrible for cracking. Oil seem clean?
I had an intake crack on my 96 and it leaked antifreeze into a few cylinders. Luckily it was just after completing the project and I was keeping a very close eye on everything. Instead of gettin a new plastic one I went with a typhoon from am. I would still pull it off and look for even slight cracks, and check my intake gaskets just to be on the safe side. It's easy an well worth the small amount of time to be 100 percent sure its just the o ring.
Be thorough when checkin it. Only takes a slight crack in those or a slight break in a gasket to leak an they do crack often. I did a pi swap an put the typhoon intake on to avoid plastic intakes. I haven't found any aluminum non pi intakes yet but haven't looked to hard for one. Keep me updated and let me kno what you find!
Have the same problem I pulled my intake off yesterday and the plastic is cracked under the thermostat where the thermostat housing meets the intake .. These intakes suck.. My car is 03 gt
Did you already see the intake to replace?? I was looking on AM and there is a 180dlls replacement from Ford Racing whit a lot of reviews and good comments… but I was thinking is not the same FORD Zhit?
Originally Posted by mdelao
I'll take the stang to the shop tomorrow to make sure that is crack on it
Did you already see the intake to replace?? I was looking on AM and there is a 180dlls replacement from Ford Racing whit a lot of reviews and good comments... but I was thinking is not the same FORD Zhit?
Did you already see the intake to replace?? I was looking on AM and there is a 180dlls replacement from Ford Racing whit a lot of reviews and good comments... bIut I was thinking is not the same FORD Zhit?
Intake is a really easy job. Pull throttle body an plenum then fuel rails an unbolt it. All you need is a 8 10 an 12mm socket. Most of those intakes on am are pi intakes if I'm not mistaken. Id find aluminum if possible because I recently replaced a plastic one with another an bout 2 months later one of the metal rings the fuel rails bolt into wiggled out somehow an unseated some Injectors. If your goin for just a quick cheap fix for now then is hit eBay or a junk yard up before I bought a new plastic intake
I will keep you guys posted I I’ll try to post for some pics
Nothing yet. Hard work all this week, the car stops leaks when water level is in the bottom of the water deposit. Next week I will be out of the city so the stang will be waiting until I return. I will keep you posted
