Engine noise (ticking sound)
Old Apr 22, 2012 | 09:31 AM
mdelao's Avatar
hello hopping you guys can help to find out what is happening. i just replace belt tensioner pulley and delete the upper idler pulley (i had to do that because alloy threads were scrubbed, also replace for smaller belt)
the sound is harder at idle and when rev up the ticking noise is not noticeable
any idea?
Old Apr 22, 2012 | 09:44 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Belt flopping any? Almost sounds as if the tensioner is "jumping"
Old Apr 22, 2012 | 10:06 AM
mdelao's Avatar
The tensioner looks good when rev up and there is no squealing on the belt
Old Apr 22, 2012 | 06:27 PM
White94GT's Avatar
The bearings could be shot!
Old Apr 23, 2012 | 10:24 AM
mdelao's Avatar
Even if the ticking gone up to 1600 RPMS?
Old Apr 24, 2012 | 10:08 PM
02PONY's Avatar
Could be your timing tensioner/guides
Old Apr 26, 2012 | 06:33 PM
jkstang78's Avatar
Check your spark plugs. I had a ticking noise on my lightning and blew out a loosw plug. My friend just told me about a ticking noise yesterday on there mustang. And the plug blew out later that day.
Old Jun 25, 2012 | 01:33 PM
mdelao's Avatar
Update, the noise has increased ( not too much) I just remember that the sound just stared the day that I replaced the stock mufflers whit the SLP LM2, should in relate that?
no smoke, MPG are normal, no power loss. the car runs perfect, someone has any idea?
Old Jun 25, 2012 | 01:36 PM
mdelao's Avatar
The noise comes from driver valve cover, and is harder than timing cover ( I used a stethoscope)
Old Jun 25, 2012 | 08:12 PM
97GT03SVT's Avatar
Ditto same deal with my 97 GT, it hasn't cased any mechanical problems though. I think the plastic valve cover has gotten loose with age
Old Jun 26, 2012 | 02:06 PM
mdelao's Avatar
Do have any plan to stop the noise?
Old Jun 26, 2012 | 02:40 PM
97GT03SVT's Avatar
It's weird when I put my hand on the valve cover it stops making the noise. I had a friend who is a mechanic look at it and he said its fine, just the plastic cover warping with age. It has been doing this for a couple years now with no issue besides the noise at idle
Old Jun 26, 2012 | 03:35 PM
mdelao's Avatar
Well I thing my issue is not as easy yours, mine obviously comes from inside, I hope was as easy as yours
Old Jun 26, 2012 | 03:49 PM
cpotts13's Avatar
The sohc 4.6 is known to have a noisy drivetrain. Mine makes a slight ticking noise, its a 2000 gt.
Old Jun 26, 2012 | 03:56 PM
mdelao's Avatar
How many miles?
Old Jun 26, 2012 | 05:02 PM
cpotts13's Avatar
How many miles?
95k. Car runs fine. Just drivetrain noise.
Old Jun 27, 2012 | 10:54 AM
mdelao's Avatar
Is as hard noise as mine?
Old Jun 27, 2012 | 11:26 AM
cpotts13's Avatar
Just watched the video, no not that loud.
Old Jun 27, 2012 | 04:56 PM
mdelao's Avatar
I was considering to change the 5W30 for a 10W30 to see if that would help to reduce the noise considering that the oil change is soon
Do you guys think that helps?!
Old Jun 28, 2012 | 10:29 PM
1999Pony's Avatar
Honestly, probably not, but its worth a shot.
5W is probably a little thin to use in the summer, but won't hurt anything.
