drivers side sitting low
Old Sep 7, 2006 | 07:09 AM
fox_box's Avatar
I posted this in corral.net but just wanting to see if anyone else can help.
i bought my car (97 gt) and the drivers side front sat lower than the passenger .. as it turns out the strut was blown no big deal i was gong to replace everything all around anyways. did that and waht do you know still sits low. anyone experience this problem before and know how to fix it.
thanks
chris
Old Sep 7, 2006 | 08:42 AM
J2D's Avatar
J2D
Have you tried replacing the springs. It's possible the drivers side springs are just worn out.
Old Sep 7, 2006 | 08:43 AM
fox_box's Avatar
i replaces all struts shocks and springs. still no fixie the problem
Old Sep 7, 2006 | 08:52 PM
hamstang58's Avatar
If the springs and struts have been replaced, the most likely problem is a lower control arm is bent or a knuckle is bent. Have you had the alignment checked? A good alignment tech can tell if anything is bent or out of place.
Old Sep 8, 2006 | 07:11 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Also on the springs, make sure hte rubber isolaters were put back in place on the drivers side. If they werent, and they were put in on the passenger, that could make as much of a 1/4" difference.
Old Sep 18, 2006 | 06:45 AM
tricky02GT's Avatar
Did you find out what the problem was?
dave07
Oct 4, 2015 06:07 PM
poldrv
Aug 18, 2015 06:42 AM
glo106
Aug 11, 2015 08:29 AM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
MADSCOTSMAN
Jul 22, 2015 04:57 PM
