Door actuators
Door actuators
What's the deal with these? My pass. Side window will not go up or down. The slides were jammed . I got that fixed so the window will at least manually be pulled up and down. The motor teeth and gear teeth won't mesh! Any suggestions? Please?
I know you sent this in May. I am new member. This past weekend my driver window stuck in the down position. On another mustang forum a member advise me to hold the button down in the direction you want the window and then slam the door. I couldn't believe it but it worked.
