Changing starter on 04 gt
Old Aug 6, 2012 | 05:50 PM
steelhorse06@hotmail.com's Avatar
Does anybody know how hard it will be to change a starter on a 2004 gt mustang. It says the starter has 3 bolts, but when I get underneath of the car I only see 2.
Old Aug 7, 2012 | 11:11 AM
yea that third one is a bit of a drag. You will need anout a 6 inch extention to get to it.
The bolts are at 6, 9 and 12 o'clock positions. The 6 o'clock is the easy one. The 9 o'clock you can get with a long extension. The 12 o'clock position bolt cannot be had with long extensions or swivels. I used a socket and a short extension. Total length of socket and extention was 6.5 inches.
Old Aug 7, 2012 | 07:06 PM
I got the 6 o'clock and 9 o'clock bolt out today. I can't even see that third bolt. I'm not real sure how I'm going to get to it.
Old Aug 8, 2012 | 02:00 AM
cntchds's Avatar
At least your car had all three bolts... When I took mine out the first time I searched for about 45 minutes for the other two bolts before I decided to just undo the one I could see/find. Then the whole thing fell on me.
I am completely convinced that at the factory they built the entire car around the starter.
Old Aug 8, 2012 | 05:40 AM
I feel the same way.
Old Aug 8, 2012 | 08:11 AM
get yourself 6.5 inches worth of extensions and go for it. Its not bad once you get the socket on that third bolt
Old Aug 11, 2012 | 08:34 AM
did you get it done yet?
Old Aug 11, 2012 | 08:46 AM
Not yet
Old Aug 11, 2012 | 11:13 AM
cpotts13's Avatar
Sweet baby Jesus I have made like 3 attempts to get that pita 12 o'clock bolt of. I have used all sorts of extensions and swivels. No luck for me. I may just take it to a mechanic and have them remove that one bolt. On the side note, when you do get it off LEAVE IT OFF. Its okay with just two. Also let me know how you did it.... I need to change my fang motor mounts and that ONE bolt is the only thing stopping me.
Edit: you can see the third bolt if you remove the passenger wheel and look between the k member and the body. You have to angle the flash light just right.
Old Aug 11, 2012 | 12:47 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
I did mine with more extensions.. bout 3 ft all together. Two wobbles were used.. I can do it fast now
Old Aug 13, 2012 | 04:59 AM
I will probably just take it to a mechanic. I tried for three hours to get that bolt out, and it never happened.
Old Aug 13, 2012 | 12:43 PM
Did you try with the 6.5 inches of extentions like in the picture I posted?
Old Aug 13, 2012 | 05:52 PM
cpotts13's Avatar
+ 1 I'm giving this a try when I get back from vacation.
Old Aug 13, 2012 | 06:12 PM
go over to Steelhorse's house and try it there first??
Old Aug 13, 2012 | 06:22 PM
cpotts13's Avatar
That could work.
Old Aug 14, 2012 | 01:25 PM
Talked to my mechanic today, I didnt even tell him what make and year the car was. I just told him I was having trouble getting to the third bolt, he looked at me and said let me guess it's a 04 mustang. I was like ****. He said he had his little special tool that he made to get to it.
Old Aug 14, 2012 | 02:00 PM
cpotts13's Avatar
How much is he gonna charge?
Old Aug 14, 2012 | 08:41 PM
1999Pony's Avatar
Its really easy. Takes me less then 5 minutes. Use a short extension, then swivel, then long extension. Shouldn't take any time at all.
Old Aug 14, 2012 | 09:46 PM
cpotts13's Avatar
Where are you located? I could use a hand..
Old Aug 14, 2012 | 10:22 PM
1999Pony's Avatar
VA. Pretty sure that would be a nice drive for you
