can anyone help
Old Jun 11, 2004 | 01:27 AM
chadstang's Avatar
i have a 94 gt that has a carb moter in how do i find out what this moter is
also what is a good way to tell what gears are in your rear without opening them up any info would be nice
Old Jun 11, 2004 | 11:58 AM
PearBear's Avatar
shouldnt be too hard, but if you post some pics, im sure someone will know
Old Jun 11, 2004 | 12:12 PM
Evil_Capri's Avatar
Ran across this:
"I was in the process of beginning to disassemble what is left the blown
302 my buddy gave me. While looking through my rebuild manual I noticed
a chapter on engine identification. I was curious to see exactly when
and where it was made etc... etc... I still have the old intake manifold
and the number on it didn't match the number on the block that is cast
into the block itself (block no. "D9AE-6015-ED-23" . Unable to figure
out what these numbers stood for I called an reputable engine rebuild
shop. Good or Bad I found out that I own a 1977-1986 351 Windsor."
Try and find some cast numbers(block) and go from there.
Old Jun 11, 2004 | 12:37 PM
Galaxie's Avatar
I Have Admin Envy
For gear ratio:
lift up rear of the car.
mark a line on the driveshaft.
turn either rear tire one full turn
see how many times the driveshaft turns, example 3.5 revolutions is a 3.50:1 ratio.
Old Jun 22, 2004 | 05:02 AM
chadstang's Avatar
thanks for the great 411 i will do that
