Best audio speakers?
Old Jan 20, 2014 | 12:31 PM
justin1996gtmustang's Avatar
1996 ford mustang what are the best quality speakers to use? And what are the sizes I know that backs 6x9 fronts? And better to use stock hook up or power it to my subs and amp my amp is 800w can be bridged to run speakers and my sub thanks guys!
Old Jan 21, 2014 | 08:29 PM
04stang523's Avatar
If I'm not mistaken the mustangs have 6x8 speakers in the front and back. I just put the kenwood KFC C6894PS in my car with an external amp and I love the way they sound. They're economical and sound great IMO
Old Jan 21, 2014 | 08:57 PM
Awesome thanks I have my sub wired to my amp so I think I'm gunna get some good sounding speakers with tweeters and hook it to my aftermarket stereo or if I'm getting speakers with tweeters should I be powering them with a separate amp? And use a power converter
Old Jan 21, 2014 | 09:02 PM
04stang523's Avatar
I would get a separate amp. I bought a hi finis amp that matched those speakers RMS perfectly and I haven't heard any distortion. Did your mustang come with the Mach 460 radio?
Old Jan 21, 2014 | 09:17 PM
04stang523's Avatar
**hifonics amp
Old Jan 21, 2014 | 11:23 PM
I'm not to sure there was already an aftermarket stereo so I upgraded it to a better one that has sub setting I will most likely do that, get like a 300w amp for 4 speakers ? And use the converter would I be able to run power cords from one amp to another? Or do I have to re run a wire set for another amp
Old Jan 22, 2014 | 05:58 AM
04stang523's Avatar
I would run separate power wires. What will happen over time is they'll start to burn out. 300 watt amp sounds goods. But you should make sure it's 300 watts rms so 75 watts per channel.
Old Jan 22, 2014 | 07:02 AM
04stang523's Avatar
I forgot probably the easiest thing to do is run the power wire from battery to a distribution block in the trunk. Then run the power wires from the amps to the distribution block do it's a shorter distance. Now depending on what gauge your power wire is determines the size of distribution Bloch.
Old Jan 22, 2014 | 08:34 PM
Ahh right on, I got the 1500w wire set from I think canadian tire or princess auto, and hooking it in the trunk sounds way better I can cut a bit off my power wire to re run the amps 👍and I was wondering for a sub mine are alpine type s, would a monoblock amp? I think it is would would those be better for base Insted of my 4 channel amp that can run speakers and sub
Old Jan 23, 2014 | 07:30 PM
04stang523's Avatar
I would always go with a mono amp for the subwoofer. The alpine type s is a decent subwoofer. Good luck with the project.
Old Jan 23, 2014 | 11:10 PM
Thanks for the help man! I have it hooked upto a dual amp from walmart lol sounds not bad, but my Forman has a 1200w mono amp idk if it works tho
Old Jan 24, 2014 | 12:02 PM
Mach1Maniac's Avatar
Best speakers for the price in my opinion are the Alpine SPR60c you can get a pair for under $200 and they push some serious power. Had them in my truck before I sold and wow...talk about jamming with clarity.My dad thought they were louder than the $800 speakers he bought from Boston. Would recommend a powerful amp for them though. Atleast 100 watts per channel. 125 watts per channel would be perfect
Old Jan 24, 2014 | 12:03 PM
DON'T DO ALPINE TYPE S SUB PLEASE!!!
Get a 12" alpine type r!! Amazing sound quality.
Old Jan 24, 2014 | 05:09 PM
That's dope I love those type r's! I just recently got subs, y buddy gave me those type s for 150$ with a box, they sound great in my car, but only thing is my stock speakers are ****y lol they sound good still but certain songs it sounds disgusting I'm thinking even just leaving my set up and just changing the speakers with better ones and leave it running off my stereo, I can change the dbz that go into my speakers through the stereo so I think just replacing them it will sound great after! I just need some nice sounding speakers that I can turn up loud if I want and not distort
Old Jan 24, 2014 | 10:33 PM
Definitely the alpine spr60c if you can get the right amp for them. Super, super clear and no distortion.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
PonyMuscletang13
Sep 24, 2015 01:40 PM
scott6809
Sep 12, 2015 11:44 PM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
