96' GT wont shift into and out of gears. NEED HELP
Old Dec 20, 2011 | 08:44 AM
Mustang_Madness's Avatar
I need to know what to do to fix my car. Its currently not drivable because I cant get it out of second or 1st when the car is on. Only when it is off can i switch gears easily. Heres the weird part. In the morning, it worked fine. And when i just got off work to drive home, it did that. When the car is on and in gear, itll start going slowly by itself With the clutch pushed in. And the more i let out the clutch, the faster the car will go, with pushing the gas!! I really need some help..
Old Dec 20, 2011 | 08:45 AM
Sorry, WITHOUT pushing the gas. Itll roll faster..
Old Dec 20, 2011 | 10:15 AM
Poisoned Pony's Avatar
Sounds like the pressure plate or the throw out bearing. Either way your trans has to come out.
Old Dec 20, 2011 | 11:49 AM
JDF's Avatar
JDF
+1 the clutch isn't disengaging
Old Dec 20, 2011 | 12:00 PM
cpotts13's Avatar
Get the clutch replaced along with a new tob and machine the flywheel...
Old Dec 20, 2011 | 12:30 PM
JDF's Avatar
JDF
Then whoever put the throw out bearing on put it on wrong. Happened to my buddies Evo. Did you do it, or did a shop do it?
Old Dec 20, 2011 | 01:20 PM
cpotts13's Avatar
If a shop did it, get it fixed and check to see if it damaged anything else...
Old Dec 20, 2011 | 01:46 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Adjust the clutch quadrant under the dash. Easy fix. Transmission doesn't have to come out.
Old Dec 20, 2011 | 03:26 PM
Alright so i dont have to replace my tranny?! Wooohoo! I love it. How much will all that stuff cost? And products i can use? I want it to be powerful, fast, and sounding awesome. I have the stereo under control but its under the hood i need to deal with. I want to supercharge it and get a 5.0 but thats a while off..i just want to accelerate fast and look good. Im doing a GT/Cobra conversion.
And also, it worked for a while and then not at all. Wouldnt i have known a while before?
Old Dec 20, 2011 | 03:29 PM
Bear Eats King...
Bear ****s Bone
No your tranny is fine. You dont have to buy anything to adjust the quadrant. There is a video on YouTube that shows you how to do it. Takes about 30 seconds to do it.
Old Dec 20, 2011 | 05:10 PM
And what does that do? Fix my problem and i can drive it? Or just an extra thing i can and should so
Old Dec 20, 2011 | 05:17 PM
Bear Eats King...
Bear ****s Bone
Fixes your problem
Old Dec 20, 2011 | 06:14 PM
Sweet! Thats awesome. Forsure or probably?
Old Dec 20, 2011 | 08:20 PM
houtex's Avatar
DO IT and you'll find out, eh? Stop posting man, and get under that dash!
/If it doesn't then take it to the shop and MAKE them fix it.
Old Dec 21, 2011 | 12:08 AM
Got it. I just dont wanna put more money in where i dont need it yet. Ya know? But i will.
Old Dec 21, 2011 | 09:28 AM
I just got an estimate with a transmission shop and they told me itd cost 350$ for labor to take out the tranny and they dont know whats wrong with it. I have to be certain that these parts will fix it. Or adjustments..
Old Dec 21, 2011 | 10:01 AM
Bear Eats King...
Bear ****s Bone
Or you could spend 0$ and do as I stated above and fix it in 30 seconds.... Your car your call.
Old Dec 21, 2011 | 11:47 AM
I gotcha! Thanks man!
jim010
Jun 24, 2024 04:23 PM
Gigantor
May 11, 2023 07:31 PM
K.A.I.N
Sep 25, 2015 03:27 PM
