94-95 ECU swap?
Old Jun 4, 2014 | 07:15 PM
The Mad Dooby's Avatar
94-95 ECU swap?
Has anyone ever swapped out the ECU in a 94-95 GT for a 90-93 ECU? I heard the 94-95 ECU isn't very good for tuning if you are planning on adding some serious power, and that some people swap to the Mass air units from the Fox's. Any info on the swap would be great, especially on how the airbags and anti theft is effected.
Old Jun 4, 2014 | 07:23 PM
AlsCobra's Avatar
A Man Just Needs Some....
Most tuning I have seen on the fox bodies or even the 94-95 is mostly manual. You really can get around any ecu tuning with parts tuning. So I really don't see the swap or even a chip necessary.
Old Jun 4, 2014 | 10:07 PM
Alright. I hope it can keep up with a twin turbo 408 stroker. I heard they are pretty versatile though. Thanks for the advice!
Old Jun 5, 2014 | 07:25 AM
zeroaviation's Avatar
This is where I always start. Trying to twist the distributor, and adjusting fuel pressure.
However, in some cases, especially FI, you have to make changes to dashpot, MAF transfer, etc.
Just depends on how it idles, and the MAF you use.
Good luck! Let us know if you have any questions, or if you need help tuning it.
Cheers,
-Matt
Old Jun 5, 2014 | 08:51 AM
AlsCobra's Avatar
Originally Posted by zeroaviation
This is where I always start. Trying to twist the distributor, and adjusting fuel pressure. However, in some cases, especially FI, you have to make changes to dashpot, MAF transfer, etc. Just depends on how it idles, and the MAF you use. Good luck! Let us know if you have any questions, or if you need help tuning it. Cheers, -Matt
Yep. Bigger fuel system, MAF size is always tricky. Possibly ignition upgrades. The old ECM is so primitive that you almost forget it's there. You just trick it into thinking it's still stock.
Old Jun 5, 2014 | 10:12 AM
Old Jun 5, 2014 | 10:17 AM
Well, one thing off the to do list. And twisting the distributor advances the timing I assume. Not something I've ever done before, but I could try it out.
Old Jun 5, 2014 | 03:49 PM
AlsCobra's Avatar
If you're going with a turbo stroked pushrod motor setup, leave the tuning to the pros. That thing will need to be dyno tuned by a high level tuner. Nothing a simple timing adjustment will do for you.
Old Jun 5, 2014 | 07:05 PM
The more I can do myself the better, but I agree. A motor shop should tune it. Luckily a family friend of ours owns a custom shop, so I'm in luck! I'll talk to him about it, I think they've built a 600+ hp SN-95 before
Ray11
Sep 25, 2015 12:43 PM
Grabber5.00
Sep 13, 2015 06:53 AM
