1994 Mustang GT Stick Transmission Lost Fifth Gear*
Old Jun 2, 2013 | 07:56 PM
Dave71's Avatar
I have a question, just wondering if someone could answer this, I have a 94 gt with stock t5 5speed trans. I was on the highway in 5th and suddenly it popped out like it went to neutral and now there's nothing there. Why did it do this??
Old Jun 3, 2013 | 04:06 PM
Vader99's Avatar
What exactly do you mean by "now there's nothing there"?
Old Jun 3, 2013 | 05:24 PM
Dave71's Avatar
I can put it in 5th and let the clutch out and it does nothing! No noise not a thing just like its in neutral. 1st thru 4th perfect, 5th nothing. It's the strangest thing. Every one I talk to don't know either. It's a 4 speed now!
Old Jun 3, 2013 | 06:50 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Hmmm. Only way to know is open it up. Might have broke a shift fork
Old Jun 3, 2013 | 11:13 PM
Dave71's Avatar
Ya probably, I guess il have to take it in and get it fixed. Thanks for the info
Old Jun 4, 2013 | 07:33 AM
bluethunderhorse's Avatar
Either a broken shift fork like stated, or the actual gear has came off the end of the shaft.
Old Jun 4, 2013 | 08:33 PM
shaunrc's Avatar
Could be a detent ball. The dent ball keeps the trans in gear by a spring pushing on the back side of the ball if the springs is worn this could cause it to pop out as well
Old Jun 5, 2013 | 05:29 AM
Dave71's Avatar
Ok, is it a matter of just fixing the transmission? Or does it need to be rebuilt?
Old Jun 5, 2013 | 09:08 AM
1999Pony's Avatar
Depends on the actual cause. If its the shift fork, that's an easy fix, anything else I would get a rebuild done.
Old Jun 5, 2013 | 09:28 AM
Bear Eats King...
Bear ****s Bone
Still gotta pull it apart for a shift fork.. might as well rebuild
Old Jun 5, 2013 | 11:17 AM
1999Pony's Avatar
Mine was inside the bellhousing. Other then dropping the trans it was simple. No reason to open up the trans to do it.
Old Jun 5, 2013 | 05:35 PM
Bear Eats King...
Bear ****s Bone
0.o I think your confused with the clutch fork.... all shift forks are internal round the gears themselves.
Old Jun 5, 2013 | 06:25 PM
1999Pony's Avatar
Yea I am
Old Jun 10, 2013 | 08:36 AM
Dave71's Avatar
Great, now my starter is acting up! It starts no problem when the engine cold but when the engine is hot the starter does nothing! I let it cool down for about half hour to an hour it then starts no problem. Must be the solenoid on the starter??
Old Jun 10, 2013 | 08:41 AM
Bear Eats King...
Bear ****s Bone
oceantracks
Mar 2, 2014 02:17 PM
airoscar
Jul 12, 2012 11:07 AM
deshawnb50
May 28, 2011 09:27 AM
Vorheez
Feb 13, 2011 06:25 PM
s281sc
26
Jun 14, 2007 04:45 PM
