04 gt cam questions
Old Aug 10, 2017 | 08:02 AM
coryc1200's Avatar
04 gt cam questions
I'm at a point with bolt ons where cams are the next step. My stang has virtually every bolt on caí, upper plenum/throttle body, pullies, full exhaust w/long tubes 3.73 gears and a bama tune. I'm mildly content with the curent set up but want to add cams for the loopy idle and some more power/rpms. But I've read quiet a few posts of people doing cams on the 2v and coming out with almost no power increase??? Like less than 5 on a dyno. Not that I care too much about dyno numbers but def don't want to drop $1000+ into my car just for a loopy idle and 5 hp. I've read other posts where guys are getting closer to 30 hp which I don't really expect to get that much... is there a trick to the cam install or is it part of the whole set up? Btw I still have the stock inake manifold. Any info would be much appreciated especially if anyone has done cams and speak on the experience. Thanks
Old Aug 10, 2017 | 01:25 PM
The 00 thu 04 were terrible for mods in that dollars for hp are way off from what you would think. When I was rebuilding my 2k engine I looked into all sorts of mods but shot them all down because it was way to much cash for the few hp I would have gained for the money. Cams tend to change where the power band is.
Old Aug 10, 2017 | 03:30 PM
coryc1200's Avatar
So maybe forget the cams and just save up for forced induction? Or maybe just sell my current stang and upgrade to a newer one...
Old Aug 11, 2017 | 06:07 AM
I would say yes to either one. But would lean more towards upgrading to a newer year. The 05 + GT's are so much better than the previous year GT. Huge improvement.
