'02 Mustang GT Flywheel hickup!
After some time saving some money I went ahead and did what was next on my "to do" list, a lighter flywheel and spec II clutch. All went well and no problems until I was standing beside my car one day and heard a chirp noise. Wasn't sure what it was, but was not there before the Flywheel and Clutch upgrade. It was very noticable and easily heard from a good 10ft away. The noise goes away if the clutch is pressed in at least an inch or more. I have had the flywheel looked at twice and each time they claimed they have fixed it, unfortunately they have not and my tolerance is running low. I am asking if anyone may know what may cause this chirp noise or if it standard going to a lighter flywheel. Also, while sitting and in neutral, the car has a very "windy" sound to it but, again, if the clutch is pressed in it becomes much more quite.
Sorry for the long post. I hope that is enough info, if not I will post more upon any question you need to know.
Current Mods:
2002 Mustang GT: Cold Air Intake, Plenum, 75mm Throttle Body, Magnaflow Cat Backs, Mac H-Pipe, Pulleys, Chip, Thermostat, Lowering Springs, and Short Shifter.
Current Mods:
It honestly sounds like the throw out bearing more than anything. I'll try to get svopaul towards this thread as he has installed numerous spec clutches (including mine).
Sounds like a throwout bearing...but without hearing it I am only guessing based on your description. When you push the clutch pedal it puts pressure on the throwout bearing and 99% of the time when the noise goes away it indicates that to be the culprit. There may be nothing wrong with it other than the noise or it could be a bad one. I have had a couple of clutches lately have no noise upon installation and not long after develop a noise in the throwout bearing even though nothing is mechanically wrong with it.
So basically you think it isnt the flywheel but the clutch instead if I understand you right. I will let them know next time I speak with them if they have checked the Throw Out Bearing.
I am still, though, leaning toward just removing either the flywheel or both due to the fact that my gearshift acts like a speaker for the flywheel vibration it sends. I just cant handle the "windy" noise and my gear shift raddling so bad. I agree that it would be something much easier to explain if you could hear it personally.
I will do some more reading the forum also to see if anyone else has had a similar problem like this. Thanks for the quick response.
7/20/15 06:26 AM
