0-60?
Old May 20, 2011 | 08:47 PM
Stackel's Avatar
0-60?
My 98 gt went from 0-60 in 8.2 sec whats wrong with it? Is that normal? the only after market parts I have is glass packs.
Old May 21, 2011 | 12:31 AM
Ddejesus523's Avatar
That's not normal at all. You should be in the 6.5 range
Old May 21, 2011 | 06:38 AM
Hawaii 5.0's Avatar
Seems way off, im agreein with the other guy u should be around 6.4-6.8. What kinda condition is ur car in?
Old May 21, 2011 | 08:21 AM
Stackel's Avatar
the exterior is a little rough but the engine seems perfectly fine. it has 145k on it but I don't believe that it would go that slow. I had a just filled up and dont think that would make it an extra 2 seconds...I only got it a few weeks ago and i'm not sure what the last guy did to it or what the 0-60 time was.
Old May 21, 2011 | 03:03 PM
Hawaii 5.0's Avatar
Hmm, 145 is alot but ive some stang with 200k on em and they run fine. Not sure what the deal is?
Old May 21, 2011 | 05:05 PM
Stackel's Avatar
Me either that's why I'm worried.
Old May 22, 2011 | 11:32 AM
Maybe there's gunk in the engine. Some mechanics have swore by seafoam that might help a little bit.
Old May 22, 2011 | 11:57 AM
Stackel's Avatar
I plan on doing a pi swap soon and I'm going to check for that.
Old May 22, 2011 | 12:21 PM
If your doing a PI swap get if from American muscle they're only like $170 on that website.
Old May 22, 2011 | 03:56 PM
Everett's Avatar
I have a pair of Windsor heads and the complete intake/plenum and injectors if you want them. Its everything you need to make the swap a breeze. The plastic intake doesn't leak and heads have 80k on them. I just ordered new cams and have a pair of heads being ported and polished. I will even include a bbk cai or the stocker. Pm me if your interested
Old May 30, 2011 | 09:34 AM
Nate98stang's Avatar
Ur car a 5 speed my car does it in like 14 it's an auto but the tranny is also going out lol
Old May 30, 2011 | 10:18 AM
Everett's Avatar
****. I swear I can get that done in 6 seconds. After cam install this weekend she will be quite quicker
Old May 30, 2011 | 11:01 AM
sinisterbullitt's Avatar
Change the plugs synthetic oil better gas an see What happens. If nothing it might just be you need a little practice. Nothing against you but it took me awhile to get in sync with my stang. Practice makes perfect. Good luck tho
What are your shift points? Or is it an auto an are you spinning tires through 1st cuz that'd do it. How do those glasspacks sound by the way
Old May 30, 2011 | 11:38 AM
Everett's Avatar
And try this stuff called lubro-moly. It is a friction reducer. Works great and I am skeptical of all oil additives but this moly really works. And if your gonna go synthetic the only true synthetics out there are red-line,Amsoil,royal purple and mobil has a line of real synthetic but mobil 1 EP or something. Not the regular mobil 1 tho. And if you have an 04 or older DO NOT USE 5w-20. I suggest a 0w-30 or 0w-40 for the best possible protection. And forget the 3000 mile oil change if your gonna go synthetic. Follow the oil manufacturers recommendation when to change. Amsoil 0w30 sso line will go 25000 miles before it needs changed. The xl line goes 15000. In an older vehicle use the xl line. It has more zddp for decreased wear and it has gasket conditioners. Happy driving
Old Jun 28, 2011 | 04:32 PM
Stackel's Avatar
It's an auto and the tires to spin a little. And the glass packs sound amazing .. The neighbors hate them..
CiniZter
25
Apr 28, 2016 05:41 PM
lysingerjj
Sep 2, 2015 08:24 PM
Rins05GT
May 28, 2005 10:35 PM
Original Sin
Canada
22
May 20, 2005 06:28 PM
armyguy
Dec 7, 2004 04:53 PM
