Valve cover painting and blasting upper intake
Old Jan 20, 2013 | 04:17 PM
Blackout's Avatar
Attached Thumbnails Valve cover painting and blasting upper intake-image-797937467.jpg   Valve cover painting and blasting upper intake-image-1845131643.jpg   Valve cover painting and blasting upper intake-image-1426948984.jpg
Old Jan 20, 2013 | 04:18 PM
Blackout's Avatar
I'm painting my valve covers metallic black. And sand blasting upper intake. Will show results
Old Jan 20, 2013 | 05:17 PM
shurtual86's Avatar
I've been thinking about painting my valve covers for a while, just don't know what color.
Old Jan 20, 2013 | 05:42 PM
Blackout's Avatar
Metallic black
Old Jan 20, 2013 | 06:02 PM
Blackout's Avatar
What's the torque for the valve covers
Old Jan 20, 2013 | 09:15 PM
shurtual86's Avatar
72-108in/lbs
So about 10ft/lbs, which seems crazy low to me but
http://www.muscularmustangs.com/2005/torquespecs.php
Old Jan 21, 2013 | 03:13 AM
Blackout's Avatar
I can guarantee ford had them tighter that that lol
Old Jan 21, 2013 | 03:14 AM
Blackout's Avatar
Not going to paint valves instead I will buy aftermarket. BBK that I can find at o'reillys
Old Jan 21, 2013 | 04:26 PM
Blackout's Avatar
Blackout's Avatar
I got one valve cover done
Old Jan 22, 2013 | 09:51 AM
skunk21's Avatar
no, trust me it isn't very tight at all even on the V8's. actually too tight and they leak.
nice job
Old Jan 22, 2013 | 07:27 PM
Blackout's Avatar
Old Jan 22, 2013 | 08:19 PM
Blackout's Avatar
So 72 is too loose and 108 too tight?
Old Jan 22, 2013 | 09:29 PM
shurtual86's Avatar
That's the range, you wouldn't want to tighten more than 108in/lbs or less than 72in/lbs
Old Jan 23, 2013 | 04:55 PM
Blackout's Avatar
Went gloss black instead
Old Feb 6, 2013 | 12:22 PM
Blackout's Avatar
Car is running fine however moisture in the motor hot vapors come out when I take out the dip stick and oil cap. Like moisture vapors. Not like before. Car is trying to run smoother must have dirt in the fuel injector holes on the heads
lsingggh310
Ecoboost
Feb 7, 2016 12:26 PM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
dbent15
Sep 5, 2015 12:15 PM
