Too much seafoam
rebuild probably not. Fix your starter maybe. Then pull your plugs and turn it over for a while to push that seafoam through. Clean or replace your plugs depending on how old they are. Report back
Did that still won't crank at all I even had to get jumped. No solution. I went buy a new starter this morning the old one was fine but I tried anyways and no luck. I dumped a lot in there. So I am going to tear it down to the block and see what is going on.
Well like I previously said yes I tried all that. No plugs in car, and tried to start the motor wouldn't budge. Wether jumping the battery, or change of the starter like I previously said nothing was even wrong with the starter I had. In the past I never even had problems with the starter. However I did at onetime let my car sit up for a while with coolant in oil pan from not draining the coolant before removing the lower intake and it acted a little different ever since that day. Ill know for a fact when I strip it all down. I planned a rebuild anyways.
But if you had all the plugs out at the same time then the liquid would have been pumped out. Curious how/why the motor has seized (according to your description)?
This whole thread makes no sense to me. Seafoaming an engine turns in to a full engine rebuild. Wtf. I think smoke just came out of my ears. Not enough information to make any real suggestions. I need to know:1) does the starter spin 2) if it does, does it make a grinding noise 3) why the **** would you pull an engine to replace a flywheel/flexplate 4) why did you seafoam whatever you did with the engine not running.
