Speedometer flicker
Old Nov 24, 2006 | 08:16 AM
jicajust's Avatar
Speedometer flicker
I have a V6 2001 Mustang w/manual trans. I just noticed around 70 MPH the speedometer drops back and forth between 65- 70 MPH. Everything else seems fine. Has anyone else seen this before?
Old Nov 24, 2006 | 08:28 AM
mudshuvel319's Avatar
I've heard of this happening before, but i've never seen it personally. Does the speedo needle flicker if you set the cruise control?
Old Nov 24, 2006 | 10:10 AM
jicajust's Avatar
I was using the cruise control when I noticed the flicker. The engine RPM seems steady and the car runns OK.
Old Nov 29, 2006 | 01:21 AM
jgsmuzzy's Avatar
SOunds like the speed sensor is giving out. Best get it checked, just so that you can be sure that when the speedo is reading 70, that you are actually doung 70 and not 80!
Old Nov 30, 2006 | 11:25 AM
jicajust's Avatar
Speedometer flicker
The one thing I've tried is clean every grounding point I can reach. I cleaned the battery as well. So far, the flicker hasn't returned.
Horsev6
Sep 21, 2015 10:27 AM
irobles
1994-2004 V-8
Sep 20, 2015 04:30 PM
Allen Hanback
Sep 14, 2015 04:37 PM
Kev006
Jul 8, 2015 05:29 AM
