Need help please!!!
Need help please!!!
I have a 94 v6 and i cant keep it running. When i start it, i have to give it gas to keep it running. It wont idle by itself. I have put a new fuel pump and filter on it and it hasnt helped. Can someone please help me out??
once you get to that point then we can move along further.
The exhaust you have shouldn't cause an issue.
Get some codes checked, it is still all guess work right now. Like I stated then we can move on. Real quick you can look under the hood to see if something is unplugged wiring or vacuum wise, even checked for aged/ worn vacuum lines real quick but still the idle issue could be anything right now.
I don't have tons of time right now but you have on OBD1 system. The code readers are dead cheap or google how to use a paper clip to use has jumper on a ford OBD1 plug, you then would have to count the check engine lights has they flash and go through the KOEO procedure. just make sure you count the correct. Most OBD1 readers are 20bucks or so.
