Just bad gas??
Old May 4, 2013 | 09:23 AM
mhmdmustang's Avatar
Just bad gas??
I've got a 2004 Mustang V-6. It was running perfectly fine last Friday and then I filled up with gas (87) and it started sputtering slightly. The check engine light came on on Saturday, so i had the code checked and it was OBD II-302 (misfire on cylinder 2). I replaced all the plugs and plug wires. This seemed to have fixed the problem until I filled up again (this time with 93), and the sputtering came back, as well as the check engine light (OBD II-304 this time). It still runs good, but when i get on the accelerator hard it starts sputtering a little. I'm hoping this is just a case of bad gas. Any other ideas of what the problem is?
Old May 4, 2013 | 05:52 PM
I was thinking bad fuel injector or a cylinder going bad. Do a compression test or check your injectors or both
Old May 4, 2013 | 07:03 PM
stupidgenius36's Avatar
Just Plain Rude!
Why are you changing gas? Instead of eliminating variables, you're creating them. Be consistent, and go from there...
Old May 5, 2013 | 06:57 AM
So I should've got the same gas that seemed to have caused the problem in the first place?
Old May 5, 2013 | 09:33 AM
Just Plain Rude!
Buy gas from a reputable station, and buy the octane that your car is tuned for.
Old May 12, 2013 | 06:09 PM
jamesp413's Avatar
Ignition coil pack
Old May 15, 2013 | 03:13 PM
Varilux's Avatar
+1 on the ignition coil pack... bad gas would not cause a misfire in one specific cylinder. The fact that it is jumping around from #2 to #4 points to the coil pack as well, IMO.
Rando
Aug 25, 2021 11:12 AM
NC14GT
Sep 10, 2017 04:47 PM
mx5jhb
Sep 30, 2015 04:44 PM
GLOCKer
Sep 28, 2015 05:20 PM
