Humming when i stop.
Old Apr 17, 2013 | 06:07 AM
Blackout's Avatar
My engine seems to hum when I'm at a stop
Old Apr 17, 2013 | 10:47 AM
Its not the fuel pump is it? I've been in some vehicles that you could hear it.
Old Apr 17, 2013 | 11:11 AM
Blackout's Avatar
It's under the hood
Old Apr 17, 2013 | 01:42 PM
Blackout's Avatar
It's almost the sound of maybe the pcv? Or my imagination of low oil pressure idk
Old Apr 17, 2013 | 03:01 PM
Injector going bad? I know they can make a clicking noise so I don't know about humming.
Belt noise?
Low on power steering fluid?
Vacuum leak?
Old Apr 17, 2013 | 04:23 PM
Blackout's Avatar
Hmm idk it feels like a mild grinding hmm
Old Apr 17, 2013 | 04:33 PM
BRADGTCS's Avatar
What tune is it humming?
Old Apr 17, 2013 | 05:19 PM
Blackout's Avatar
Race
Old Apr 17, 2013 | 07:00 PM
Sixpac's Avatar
Race
On my 03 v6 there was a humm and it was actually the alt pullie.. So it could be any pulley..
Old Apr 17, 2013 | 07:19 PM
houtex's Avatar
The fan makes a humming noise when it's on... Perhaps that's it? Perhaps you can take the hood off, and then do a fire drill run, running outside to hear what the problem is... or have someone at a stop next to it to figure it out.
Just throwin' things at a velcro wall to see if they stick...
Old Apr 17, 2013 | 07:22 PM
Automotive stethoscope
Or a long screwdriver
Put your ear to it and touch things very very very carefully with you car running and the parking brake on.
Old Apr 17, 2013 | 07:40 PM
Blackout's Avatar
Gotya
Old May 15, 2013 | 03:17 PM
Varilux's Avatar
If you are talking about a noise at idle, try turning the wheel from side to side, if the hum changes it could be the idler pulley (cheap) or the power steering pump (less cheap).
On my '03 vert, it was the idler pulley causing that sound.
Old May 28, 2013 | 09:39 PM
1SloSix's Avatar
well since our sixxers are known for ps whine and hum i'd aim more for it. check your fluid? also are you running power steering fluid or atf? i've found a lot of people run PS fluid not knowing ATF is what should be in it.
mx5jhb
Sep 30, 2015 04:44 PM
Rando
Sep 30, 2015 12:28 PM
tacbear
Sep 27, 2015 12:57 PM
akdoggie
05-09 Interior and Audio Mods
24
Sep 16, 2015 02:38 PM
shatter
Dec 7, 2006 09:23 AM
