-   1994-2004 V-6 (https://themustangsource.com/forums/f635/)
-   -   delete power steering? (https://themustangsource.com/forums/f635/delete-power-steering-520122/)
Blackout Mar 26, 2013 03:47 PM
What happens if you delete power steering? And is there pros and cons?
11SHELBYGT500 Mar 26, 2013 03:49 PM
Have you ever driven a car without power steering? Haha
Blackout Mar 26, 2013 03:55 PM
Yeah basically impossible to steer. Reason why I ask is bc the two nuts on the studs that hold the power steering rack in place is loose. Kinda weird
Blackout Mar 26, 2013 03:56 PM
I drove it one time deleting the powersteering with a smaller belt, and I'm wondering if possibly I may of screwed up the rack if that's even called a rack but its the part that goes to the tie rods
Blackout Mar 26, 2013 04:00 PM
1 Attachment(s)
Maybe this picture I found off the web can help, but see the stud with the nut? The whole rack moves sways when I steer, and you can tell most likely those nuts are loose... So should I just tighten those nuts up and it would be fine?
Attachment 133816
Blackout Mar 26, 2013 04:33 PM
Never mind looked at it it's made to sway
Blackout Mar 26, 2013 05:32 PM
I wish we had electronic power steering
skunk21 Mar 26, 2013 05:37 PM
A manual rack doesn't feel like a power steering rack w/o power assist. yes it is tighter at really slow speeds but easier has you get going. I have driven 2 foxes with manual conversions not all that bad, get the thought of how a car feels with failed power steering out of your head . that said leave it for a track car no real gains to make it worth it .
1999Pony Mar 26, 2013 09:58 PM
What he said. Great for track car, not worth it for a DD. To do it right you need a new manual rack. MM also has a power steering setup that tightens up the power steering so it is not so spongy like it is stock. Thats the best way to go really.
But I wouldnt do anything to yours now, throw some thread lock on the bolts and tighten them and see how that goes.
Blackout Mar 27, 2013 05:37 AM
Ill have to save that as a cookie on my phone but what's mm?
1999Pony Mar 27, 2013 07:48 AM
Maximum motorsports
skunk21 Mar 27, 2013 08:42 AM
http://www.maximummotorsports.com/store/
quality stuff. I have their parts on my car.
Blackout Mar 27, 2013 06:36 PM
So with this part would you even need the power steering pump?
1999Pony Mar 27, 2013 07:27 PM
http://www.maximummotorsports.com/st...roducts_id=446
This is the kit. They used to have one for 96-04 as well, don't know what happened to it. But you get a new pump that uses less engine power and improves the responsiveness as well.
It was around 800 bucks a couple years ago, so I would expect to pay over 1000 for it.
slow-poke Nov 5, 2014 06:30 AM
I recently installed electric power steering in a 1966 Mustang. I did not use a kit, I simply pulled a column style EPS from a newer GM vehicle and then spliced the unit into the original steering column.
The results far exceeded my expectations and the cost was less than $200. I designed a controller that automatically adjusts assist level based on vehicle speed, so that the steering feel is "just right" regardless of speed.
I documented (with pictures) how I went about this on a Vintage Mustang forum. If anyone is interested do a google search for "Best $200 mod ever (EPS)"
or
follow this link to page 7 where the details start: [URL=http://forums.vintage-mustang.com/mod-custom-forum/787114-best-200-mod-ever-eps-7.html#post6037649[/url]..
Any questions just ask.
