Car whines in 3rd
Old Oct 4, 2004 | 10:01 PM
Ballz's Avatar
I normally drive my car pretty easily but there are just days when I like to give it all its worth you know?
So yesterday I'm driving and I keep 3rd into 3000 rpm's. Upon reaching the 3000 it starts to whine. Is this normal? I don't remember hearing this before.
Old Oct 4, 2004 | 11:33 PM
Dr Iven's Avatar
Sounds like your third gear gears might be going bad.
My Ranger is doing the same thing, and I think it's the tranny because the gears sometimes make a grinding noise at idle in neutral.
I won't know until I have time to break it all loose and inspect the transmission.
Old Oct 5, 2004 | 12:25 AM
Ballz's Avatar
I don't much about cars. I'm just starting to learn. I'd hate to think my trany is going bad. Thats an expensive fix isn't it?
Old Oct 5, 2004 | 01:35 AM
jgsmuzzy's Avatar
Is it auto or manual? Does it whine in any other gears? Try holding it steady in second at 3000 revs and listen closely, if it is only third gear, you might need a tranny rebuild. How many miles has the car done?
Also, when was the last time the transmission fluid was checked?
All little things to check out!
Old Oct 5, 2004 | 02:11 AM
Ballz's Avatar
Well my transmission fluid was changed at about 30,000 and my car is around 55,000 right now. It is a manual trans.
I'll give it a try in the other gears. I've only noticed it in 3rd so far.
Old Oct 5, 2004 | 02:57 AM
Cajunsix's Avatar
I've noticed that the 3.8L aren't too quiet as far as drivetrains go. Mine has a noisy tranny in 4th and 5th at low RPM, but the car runs great.
Old Oct 10, 2004 | 11:25 AM
Ballz's Avatar
As luck would have it my girlfriends brother works at Midas! He built the engine in 5.0 himself and I trust the guy quite a bit with my car. That and the work he would do for free! *rock*
He told me the part that I need is only about $3 but it would be 3-4 hours of work. Forget what he called it exactly. He also noticed that the clutch shakes some. If this little part doesn't fix it he said I might have to replace the whole tranny but he'll do his best to do what he can.
Old Oct 12, 2004 | 12:48 AM
Cajunsix's Avatar
Cool deal . Let us know how it goes, I'm kinda curious as to what exactly was causing it. I know with my stock clutch the pedal vibrated some (there's a TSB for that).
Jim74656
May 1, 2023 02:15 AM
sarnold58
Jun 9, 2019 02:22 PM
ssjbuu
Aug 28, 2015 08:55 AM
SpeedyJoe
18
Aug 23, 2015 02:42 PM
