99 Mustang 3.8L - Engine gets cold while driving fast
Hey
I'm on aborad studies in California and bought myself a Ford Mustang a month ago for traveling. Since then i have some problems with the engine temperature.
The Problem is:
The Engine gets very cold when im driving on the freeway. As i know from other cars, the temperature needle should stay in the middle of the scale but it does not.
My Mechanic replaced a (damaged) Thermostat at first with an 180f Thermostat, later i let i replace with an 195f Thermostat. At City-driving the car reaches normal operating temperature... when i drive on the freeway the temperature falls down to almost "cool".
Do you have an idea whats happening?
I don't think the second new thermostat is damaged too...
Thank you for your help!
Lukas
The Problem is:
Lukas
Sounds like fan running while car is on highway and not shutting off
Don't know much about 99 V6's but in general if it's a non electric, mechanical fan, that runs off the accessory drive belt the clutch may have failed on the fan itself. When it's hot the fan engaged and runs with the belt, when it's supposed to spin freely and the clutch so the accessory belt still turns but the fan doesn't.
If it's a mechanical fan this is the easiest of all fixes. You would need a replacement that you can get off of rock auto or a local parts store and it's like four bolts attached to the water pump pulley and you're done. After you loosen the belt first.
But make sure that's what it is first.
Hey
The Problem is:
Lukas
The Problem is:
Lukas
LEXiiON
Are you sure you put in a higher temp thermostat? If you put in one that's too cool, it will keep cycling the radiator fluid constantly.
