3.73 Gear install this weekend
Old Mar 10, 2005 | 11:35 PM
Cajunsix's Avatar
Finally, something I should've done a long time ago. Got all the parts in and they're ready for install. This will be my first time installing a set of gears, but I have all my bases covered. I'm going to go ahead and change all the bearings and seals while I'm in there plus a rear end girdle .
[attachmentid=14379]
FRPP 3.73 gears
[attachmentid=14380]
modified cross pin
[attachmentid=14381]
Richmond Gear install kit
[attachmentid=14382]
Dallas Mustang speedcal
[attachmentid=14383]
TA peformance rear end cover
There's some other stuff like fluids, threadlocker, axle bearing/seals etc.
I'll be sure to post some pics of the install to show what's involved.
Old Mar 10, 2005 | 11:57 PM
gtstang's Avatar
nice
Old Mar 10, 2005 | 11:59 PM
Ballz's Avatar
Before I got to the end of your post I was thinking " I hope he'll take pictures and show us how its done"! Thanks for stepping up!
I think in a year or so I'd like to pick up another V6. Any year between 02-04. maybe an 05 if I find one cheap enough. I just want to make some thing faster. Learning from you guys will have to suffice for now.
Old Mar 11, 2005 | 12:01 AM
Ballz's Avatar
By the way, how much is the job costing you?
Old Mar 11, 2005 | 12:13 AM
future9er24's Avatar
cool. cant wait to see it installed and ready to go
Old Mar 11, 2005 | 12:02 PM
Cajunsix's Avatar
All the parts shown above plus axle bearings/seals and fluids ran about 600. The rear end cover isn't necesary but that added another 160, so I guess the parts would run about 450ish. I already had some of the tools needed for the install like a dial indicator and torque wrenches and stuff, so I decided to buy the few extra tools I needed instead of paying for someone to install. I spent about 200 on xtra tools, some of which I plan on using for a trans rebuild too.
Old Mar 11, 2005 | 01:15 PM
Ballz's Avatar
Awesome! Doesn't sound expensive at all for what you get!
Old Mar 11, 2005 | 06:47 PM
i agree, i thought it would be alot more. theres my inexperience talking again
Old Mar 17, 2005 | 08:23 PM
Dark02Pony's Avatar
looks like fun! you gotta let us know how you like em once they're in
Old Mar 17, 2005 | 11:23 PM
Ballz's Avatar
C'mon Cajun! Show us what you did! Report!
Old Mar 18, 2005 | 08:57 PM
The Deviant One's Avatar
Sweet! Are you still using the stock 7.5" rear or did you switch to an 8.8?
Old Mar 19, 2005 | 05:54 PM
Cajunsix's Avatar
Alright, sorry to keep you guys waiting. Ran into a few problems. I only have pics of part of the disassembly. I ran out of batteries in my camera. I will tell you that if this is a first time gear install, get someone who's done it before to help you! I found out a few things the hard way. The install took a while. A few things to note would be that a seal puller will NOT get the axle or pinion seal out. They were harder to pull than the bearings. A 20 lb. maul was required to get the pinion gear out. With 3.73s and higher, you need to put the cross shaft back in BEFORE you install the new ring gear. Everything went together well except the pinion nut wasn't tightened enough because I got a false reading on the bearing preload . I ended up having a shop fix my mistake. Doing this in your driveway is very possible, but learn from my mistakes . I'll get back later with a few pics and stuff.
Cajunsix's Avatar
BTW, 3.73s rock!
Old Mar 21, 2005 | 05:47 PM
pilot1129's Avatar
so how does it feel now?
Old Mar 21, 2005 | 05:59 PM
gtstang's Avatar
yea, i want to know if u can feel a major difference.
Old Mar 21, 2005 | 06:08 PM
gtstang's Avatar
i am not sure if I should install 3.73 or 4.10 gears to my v6 automatic. So i would like to know if u are satisfied with those.
Old Mar 22, 2005 | 12:10 AM
Dark02Pony's Avatar
automatic usually are best with 4.10
Old Mar 22, 2005 | 12:52 AM
Cajunsix's Avatar
It's a difference I can very noticeably feel. The only downside is I have to adjust to the new shift points. Gtstang, I'd say go with 4.10's for auto. Cruising RPM may be a little high, but you'll love the acceleration and how fast you rip through the gears.
Old Mar 22, 2005 | 12:56 AM
Dark02Pony's Avatar
you looking into doing trac-lock next ?
Old Mar 22, 2005 | 01:11 AM
Cajunsix's Avatar
Sorry forgot to mention I already had a trac-loc stuffed in there.
[attachmentid=15357]
There it is.
