Under load i cant rev above 5200rpm
Old Jan 13, 2012 | 05:53 PM
SVTCobraR315's Avatar
If in neutral I can rev to the limiter but if driving it cuts off at about 5k. Any ideas?
Old Jan 14, 2012 | 10:29 AM
skunk21's Avatar
could be a list of things, here are some things to take a look at..
if you have an msd box or the like it could be going out, swap with a freind or hook the factory ignition back up.
arching plug wires or cracked porcelain cracked on plugs.
failing coil
faulty dizzy more prone with aftermarket units.
check your fuel pressure under load
valve springs.
Old Jan 14, 2012 | 10:37 AM
AlsCobra's Avatar
A Man Just Needs Some....
Try a fuel filter first. I've seen them do this. Cheap and easy thing first.
Old Jan 14, 2012 | 11:23 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Weak coil should be added to the list.
Old Jan 14, 2012 | 12:09 PM
Still running OG fuel filter soooo it could be that. It's been a while for the plugs too.
Old Jan 14, 2012 | 12:39 PM
Yeah my coffee truck did that - after they switched to E10 for the winter (back in the 90's) it loosened all the crap out of the tank and plugged the filter. Started great, ran pretty good around town, but put the pedal down and it was starving for fuel. The old filter felt like it weighed about 3# lol.
Detroit Steel
May 19, 2016 12:13 PM
samjluck
Sep 17, 2015 10:24 PM
akdoggie
05-09 Interior and Audio Mods
24
Sep 16, 2015 02:38 PM
Evil_Capri
Sep 11, 2015 08:39 AM
