tune up questions
Old Aug 4, 2013 | 10:56 AM
gt50convert's Avatar
tune up questions
I have an all stock 89 5.0 im about to do a tune up should i change the distributor cap and rotor along with the plugs and wires im trying to get more spark to get some extra power
Old Aug 4, 2013 | 06:04 PM
MustangBillJr's Avatar
I would, especially if its all stock stuff. It'll defiantly help if you decide to bump the timing for some extra power.
Bill
Old Aug 4, 2013 | 07:19 PM
Ok im looking to get it running back to new im also throwing a cai on it with smog pump elim to get it extra power
Old Aug 4, 2013 | 07:25 PM
Im not looking to bump the timing but how much extra hp could it be with the bump in timing and those few mods plus i have an o/r h pipe and flowmaster super 10s
Old Aug 5, 2013 | 06:51 AM
I wouldn't be able to give you an estimate. I'd say you should feel a difference. Don't know why you wouldn't want to bump the timing though, its like free power depending on how retarted it currently is. The CAI is more of a sound mod until you do more serious work. My father and I have both run into the 12's with stock tube's & air box with a K&N panel filter.
Old Aug 5, 2013 | 04:10 PM
How much should i bump it up
Old Aug 6, 2013 | 04:56 AM
I would do the tune up, wires, plugs, and cap/rotor first just to make sure it's getting a good spark. I'd also run stock replacement motor craft plugs, should be no reason to run anything else.
Start at 12*... Some cars like more. I ran 14* in my Stangs. Then just listen for pinging(detonation) and just feel how the car reacts. You must run 93 octane though and I'd change the fuel filter if you havn't already. Usually I bump it until she pings then back it off a degree or two.
Bill
Old Aug 6, 2013 | 07:50 AM
Im trying to get as much power without running 93
Old Aug 6, 2013 | 11:46 AM
Uhh... Alright then, I never run anything lower than 93 in anything so I wouldn't have a clue what you could bump it to.
If you don't want to spend the extra money on 93 then I wouldn't waste money on a CAI either. Very minimal gains for the $. Like I said, my father and I have run well into the 12's with stock air boxes & rubber hoses. Your money is better spent elsewhere. Since your TB is only 60mm & Mass Air is only 55mm I'd start there...
Old Aug 6, 2013 | 03:07 PM
I would run 93 but the price of 93 in my state is crazy
Old Aug 6, 2013 | 03:21 PM
10* is a long time standard on many engines for all around performance and safety (ping/detonation is an expensive game).
Old Aug 6, 2013 | 07:10 PM
For power adders it may be an expensive game to play. For a stock 5 liter its fine if you bump it till it pings and back it off. We've done it to over a dozen different foxes and they all ran perfectly fine afterwards. Guarantee hes going to ping at the 6-8* its currently at running 87 anyway.
Old Aug 7, 2013 | 09:33 AM
Im running 91 in mine actually i just want some extra power without breaking the bank
Old Aug 7, 2013 | 08:26 PM
I plan on running a c&l inlet pipe will that fit the stock maf then i was going to put a k&n filter on it
Old Aug 8, 2013 | 06:48 AM
Waste of money IMO. Your CAI will only be as big as the smallest opening. In your case, 55mm(only 2.165 inch diameter) since thats the stock size mass air. Opening up the tube behind it will do nothing. I'd do the K&N drop in though. Like I said earlier, I've run into the 12's with a stock air box, stock rubber inlet tube BUT I had a 75mm Pro-M bullet mass air and 70mmtb. CAI are a waste of time with a stock motor. Your money is better spent elsewhere.
Old Aug 9, 2013 | 08:12 AM
onebadvert's Avatar
If your running 91 you may be able to bumo up to 12* without issues. Just pay close attention (as mentioned) for pinging. Its best to load the engine hard when checking as this is where detonation will most likely occur. I would bump the timing before I bought a cai or smog eliminator. It will see better gains than both. Not to mention its free. A cai is more for looks than anything on these motors. You can remove the air silincer from your stock cai to help a bit
Old Aug 17, 2013 | 12:57 PM
im going to do the tune up bump it to 13 put the k&n filter remove the silencer and put a shift kit from performance automatic in it but im not sure about that i do a lot of daily driving what kind of times in the quarter could i expect
samjluck
Sep 17, 2015 10:24 PM
Kestral
Sep 2, 2015 06:52 PM
