Timing question
Old Jul 25, 2012 | 09:47 AM
GT89's Avatar
Timing question
Im making this harder then it is but please chime in. I have a 306 with what I was told has a B303 cam. I checked the timing with the spout connector out it was retarded 10but with the connector in its advanced 10. I'm suppose to read what the arrow is at right? With or without connector in? Thanks in advance
Old Jul 25, 2012 | 05:58 PM
onebadvert's Avatar
the timing should be 10* (before) btdc. looking at the crank 0* (tdc) the mark you want is to the right of the tdc. when you remove and install the spout the motor should be off.
Old Jul 25, 2012 | 07:22 PM
GT89's Avatar
Ok I'm going to check it again tomorrow. When I checked it with the spout out I pulled it when it was running don't know if that changes reading but it was at the 10 to the left of tdc
Old Jul 25, 2012 | 07:41 PM
onebadvert's Avatar
I'm not sure if what it does but I think its best to do it off. And 10* after/atdc is way off. I'm suprised it would run.
Old Jul 25, 2012 | 08:03 PM
GT89's Avatar
It idles smooth picks up decent not where I thought it would be. A friend told me today people that put bigger valves in and has the timing down like that prolly was using nitrous, but I have no idea lol
Old Jul 26, 2012 | 11:07 AM
Hoss408's Avatar
Your timing from the factory was set at 10 deg BTDC so that consumers could run on 89 octane. As soon as Hot Rodders got their hands on the 5.0 they were bumping the timing to 12-14 deg and sometimes even higher with race fuel. Now running 12-14 deg timing you will need to run a higher octane (92) . As far as timing being set (retarded)ATDC... I'd make sure you follow the steps for setting timing... Your car would be lucky to run with timing that far out- even running a nitrous set up , the general rule of thumb is 2-3 degrees retarded per 50 hp... So even a 150 shot at @ 9 degrees retard would still not put you anywhere near your reading. There are plenty of resources to walk you through step by step on timing.. I'd suggest purchasing a chilton or Haines manual ... Good Luck with the Stang!
Old Jul 26, 2012 | 03:12 PM
GT89's Avatar
Ok thanks for all the info I didn't get to check it today guess it will have to wait until tomorrow thanks again
Old Jul 27, 2012 | 08:29 AM
skunk21's Avatar
Look in our tech sticky post #18 has the timing info.
Old Jul 30, 2012 | 12:23 PM
GT89's Avatar
Got the timing fixed on it finally, checked it before I changed it and yep 10* to the left of 0. Now it's set at 13* the right and geeze!! Feels like a whole new engine!! Makes the clutch slip in 3rd and 4th now lol thanks again guys
Old Jul 30, 2012 | 07:59 PM
onebadvert's Avatar
awsome man. good to hear. you may be alright there but just becareful to listen for detonation.
Jim74656
May 1, 2023 02:15 AM
5.M0NSTER
26
Sep 28, 2015 07:11 PM
ssjbuu
Aug 28, 2015 08:55 AM
Feffman
Aug 22, 2015 06:27 AM
Feffman
Midwest
Aug 15, 2015 08:08 AM
