Speeometer question "HELP"
Old Apr 21, 2013 | 10:01 PM
87t-top's Avatar
I just bout a 140mph speedometer out of a 1990 mustang for $25 it's in great condition. Will it fit my 1987 mustang. I have the stock 85mph speedometer.
I need a answer before I take the car apart.
Old Apr 22, 2013 | 08:58 AM
MustangFrontier's Avatar
Not sure on swaping the entire cluster, but the actual speedometers should swap as they are mechanical.
Old Apr 22, 2013 | 01:19 PM
82 GT's Avatar
The '87-93 clusters are all the same. So, yes, you can either replace the entire cluster or just the speedo if you want.
Old Apr 22, 2013 | 02:25 PM
87t-top's Avatar
Thanks ill be switching clusters sometime this week
Old Apr 22, 2013 | 04:30 PM
skunk21's Avatar
The air bag years are different
87 thru 89 speedo
90 thru 93 speedo
1987 thru 1989 cluster
1990 thru 1993 cluster
you can get the 1990 speedo to fit into the early cluster even though the mounting holes don't all line up it can be made to work but the 199 thru 1993 cluster harnesses are not wired the same as the 1987 thru 1989. There are about a half-dozen wires that are in different.
Old Apr 22, 2013 | 05:51 PM
87t-top's Avatar
87 thru 89 speedo
90 thru 93 speedo
Thanks for the Info.
Old Apr 22, 2013 | 06:15 PM
87t-top's Avatar
87 thru 89 speedo
90 thru 93 speedo
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
