Speedometer is out
Old Oct 23, 2018 | 08:52 AM
Davis93's Avatar
Speedometer is out
Hey every one I am looking for some suggestions on why my speedometer has quit working
Old Oct 23, 2018 | 09:13 AM
ALMOST STOCK's Avatar
Have you checked your speedo cable to make sure it's still i one piece?
SpectreH's Avatar
What year/engine is your car? 1979-93 cars with EFI or cruise control have a cable or speed sensor. If it is a carbureted car without cruise, it could be the cable. The drive gears in the transmission could also be worn and can be easily replaced.
Old Nov 6, 2018 | 03:10 PM
Davis93's Avatar
Found out why it quit
Found out my cable was melted from a small fire I had any one know where to get them for the 2.3l rock auto is a no go
Old Nov 6, 2018 | 07:40 PM
houtex's Avatar
They're all the same, with one caveat. An example of one:
https://www.cjponyparts.com/speedome...SABEgK23fD_BwE
The caveat: If your Fox is an *early* one (83-86) and does *NOT* have cruise control, the cable is apparently different:
https://www.cjponyparts.com/speedome...69-1986/p/SC8/
Probably a length issue.
I'm sure your sender (the gear on the transmission end) is good, but just in case:
https://www.cjponyparts.com/speedome...1993/p/HW3275/
And finally, just for grins, all things speedometer cable for an '83 or thereabouts:
https://www.cjponyparts.com/catalogs...edometer+cable
You might also check American Muscle, LMR, Ebay and Amazon, and if a vendor chimes in, them maybe, and of course you probably could go to a Ford dealer and get the things there.
Hope that helps, and good luck!
Hope that helps.
tmcolegr
Jan 13, 2005 01:00 PM
mark221
Oct 21, 2004 08:10 AM
I8URVTEC
Oct 4, 2004 04:13 PM
