Rear Trunk Latch
Old Dec 8, 2012 | 01:33 PM
SVT2209's Avatar
Rear Trunk Latch
Hey guys. My new arrival of 1992 Mustang GT has a couple issues I need some help with. I'm going to post several topics on each so I can concentrate on each. The first one is the rear trunk latch mechanism. It doesn't catch. When I physically move the latch it feels very tight but moves. It doesn't catch the pin. Is there a quick fix like spraying it or shall I just purchase another?
Old Dec 8, 2012 | 01:35 PM
sampey43's Avatar
Check with skunk21 on here!! Hes the fox god around here!!! He will be able to answer your questions!! Good luck!!
Old Dec 8, 2012 | 01:39 PM
SVT2209's Avatar
So shall I continue? Do you think anyone else can help my ?'s
Old Dec 8, 2012 | 01:51 PM
sampey43's Avatar
If you search the fox threads, i think they have a topic on this problem already! Just use your search and see what you come up with
Old Dec 8, 2012 | 02:02 PM
skunk21's Avatar
The stricker for the rear latch will adjust. you need to loosen it and it will move up/down etc. also on the under side of teh hatch in each corner are rubber bumpers they may need to be adjusted also ( just like on the under side of the hood). you can also spray wd/40 or liquid wrench up inside the latch to get the jaws to move if they feel stuck but once they move free or come into contact with striker like they should the jaws should lock around the pin.
keep in mind not to move the striker to far up, you risk not making a good seal with the hatch and water could get in.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
Evil_Capri
Sep 25, 2015 12:56 PM
TMDM
Sep 24, 2015 07:00 PM
tbear853
Sep 8, 2015 11:18 PM
