New Cam with stock 5.0 motor
Old Aug 27, 2011 | 11:28 AM
jsmith214's Avatar
I own a 89 LX hatchback manual transmission for the following modifications. 3.73 gears, shorty BBK headers, 2 1/2 inch off road H pipe with flowmaster mufflers, MSD ignition, upper and lower Eldelbrock Performer intake, 70mm throttlebody with spacer and cold air take, 3 core aluminum radiator, larger fuel sender (correct name leaving me :-) ),king cobra clutch, and installing new struts, shocks and 2 inch lowering springs next weekend. I can not afford the AFR 165 heads for a while but I am replacing waterpump and wondering if there is a Cam that will work with my stock heads without having to take them off and do any modifications?
Old Aug 28, 2011 | 08:01 PM
mystickeith50's Avatar
Any of the alphabet cams.
Old Aug 28, 2011 | 08:43 PM
jsmith214's Avatar
stock head springs
I was just going to go with the E cam looking for just a little more performace but love the sound. I am just worried about the stock springs on the heads. Motor has about 40,000. Can not afford the AFR heads for a while with all the restoration needed that I have done. I have some leaks under the hood I am going to take care of and while replacing the waterpump I was thinking about changing out the cam but wondering if worth it untill I can afford the heads.
Old Sep 4, 2011 | 05:55 PM
matt90lx's Avatar
I have an E cam with stock heads and have no problems, a little better performance but best of all the sound, it sure is nice.
Old Sep 5, 2011 | 06:39 PM
jsmith214's Avatar
When u went with the E Cam did u change out your pushrods or roller lifters or rocker arms or just slide it in?
Old Sep 6, 2011 | 09:22 PM
93slowstang's Avatar
With the E cam you can keep your stock stuff.
Old Sep 12, 2011 | 08:49 PM
matt90lx's Avatar
Just slide it on in, I used all my old stuff and have no problems
MRGTX
Apr 17, 2023 06:54 PM
Jtm90fox
May 22, 2016 01:55 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
