Install 140 Guage Cluster
Old Jun 26, 2005 | 09:11 AM
litening's Avatar
First of all my appologies if this has been discussed b4, I serached the forum but couldn't find an answer.
I have an 88 LX that I would like to install a 140 speedo in. I see a ton of these units on ebay for sale but sometimes the model years vary. Some list 87-93, others simply 90-93.
Can anybody explain if there are defferences between model years, and if it is a show stopper if the wrong unit is installed. thx!
Old Jun 27, 2005 | 08:08 PM
Coupe's Avatar
The 90-93 speedos require some trimming.
The 87-93 speedos are probably just stating (advertising) that it'll FIT in any of those years. LOOK for a 87-89 speedo! ( i.e, It came out of a 87-89 car.)
When I went shopping for my swap, I looked for a 88-90 unit so I WOULDN'T have to trim the speedo.
HERE <<<<------- is a swap write up detailing the 90-93 swap into an 87-89. If I recall, 1990 was the airbag year, making the speedo unit a tad different
The only "show-stopper" I've seen is attempting to swap a 90-93 CLUSTER into a 87-89. The wiring is different to the entire cluster, but some pins can be moved around.
HERE <<<<<----- is a pdf file for swapping wiring pins when you are swapping in an ENTIRE cluster from a 90-93 into a 87-89.
Clear as mud?
Besides, why put in a 140, when the posted limit is 70 in most states?
Let us know how you make out.
Old Jun 29, 2005 | 04:22 PM
litening's Avatar
Thanks for the response Coupe, appreciate the good info. BTW, doesn't everybody ignore the posted speed limit on occasion?
Old Jun 30, 2005 | 10:23 AM
Coupe's Avatar
Sometimes the occasion becomes quite frequent !
I swapped the 85 for a 140 speedo so "I'll know EXACTLY how fast (above 85) I was going when I do get that ticket.", is what I recall telling my wife .
Keep us posted on the progress
Old Jul 6, 2005 | 06:01 PM
svopaul's Avatar
Service Manager
Also the 90-93 Speedos don't light up the same at night so you will have issues there if you use one of those. Stick with the 87-89 speedos and you will be fine. The only 140 speedo for those years came in the '89 models...other than that there are Motorsport and Police(Certified Calibration) speedos which are 160mph versions.
Old Jul 6, 2005 | 08:10 PM
Fordracing200's Avatar
Why did they change the speedos for the 1990 model year?
Old Jul 7, 2005 | 07:18 AM
svopaul's Avatar
Service Manager
The cluster was changed to accomodate the airbag that became standard in 1990
samjluck
Sep 17, 2015 10:24 PM
Grabber5.00
Sep 13, 2015 06:53 AM
Earlsays
Sep 12, 2015 06:29 PM
SMOKE46
Sep 6, 2015 09:40 PM
