engine bay smoothing...
Old May 13, 2011 | 07:30 AM
afr347strokerman's Avatar
Here's the next project...sonic blue paint will be laid on...I wont be painting it but it would be nice lol.
Old May 13, 2011 | 10:01 AM
BoogieNights's Avatar
BoogieNights Studios:
Official Fluffer
Originally Posted by afr347strokerman
Yeah I'm new to do ing bodywork... but I plan on prime it in yellow and then priming it in black so highs show yellow and lows show black... is that a good idea? The whole looks thick because I'd started to weld on it when I decided to leave it open for my aeromotive fuel lines. It's just metal I need to grind down. Any tips would be greatly appreciated
I been doing auto body for around 18 years off and on.
Ok prime it in a light color. It can be grey, yellow, tan whatever. Then take a can of black spray paint ( dont matter what brand) and lightly spray it over the primer. Enough to show thats it there but not enough to cover up the primer completely. it just needs to be light. This process is called guide coating. Then wet sand it with wet dry sandpaper. I usually use 220 grit for this. If there are any low spots the black will show. If there are high spots it will turn to bare metal. If you can get away with using a sanding block then do so. if not what I do is take a paint stir stick and wrap it with the sand paper. Also make sure you keep whatever your using to sand with flat. Only wetsand enough to remove the black paint. If you have a black spot then sand till it either goes away or you see bare metal. If you have no black spots and no bare metal then you are good to go. Wetsand with 400 grit then you can paint or you can go ahead and wetsand again with 600 to make it smoother. I usually stop with 400 making sure that there are no sanding marks visible and everything is smooth.
Hope this helps.
Old May 13, 2011 | 10:06 AM
Evil_Capri's Avatar
Looking good! Thanks for sharing . . .
Old May 13, 2011 | 10:09 AM
Official Fluffer
Thats gonna look sweet BUT I would go with True Blue instead of Sonic Blue. I like True Blue better.
What year is that one? You gonna build it for the track?
Old May 13, 2011 | 10:00 PM
Post a pic of true blue...I dunno what it looks like. Its a 88 I keeping the efi... my 363 dart based stroker is almost outta the shop...can't wait! Got a novi 2k and vortech igloo going with it n a built c4
Old May 14, 2011 | 02:55 AM
Official Fluffer
True Blue is this deep dark blue. at night it looks black but when the sun hits it you can see that it is blue. it is an awesome color. I will post a pic later. I gotta get back to work now.
Old May 14, 2011 | 12:18 PM
Official Fluffer
This is what true blue looks like.
http://www.dogpile.com/clickserver/_...D&_IceUrl=true
Old May 14, 2011 | 02:50 PM
Looks nice but too dark for me..i like that green on you lx looks cool...ima stick with sonic blue. Why are you redoing gut engine bay? What's wrong with it?
Old May 15, 2011 | 02:50 AM
Official Fluffer
Im redoing it cuz it has a bunch of chips and nicks in it. I want it to be clean with no scratches or chips. I will be showing it too so it has to be clean. lol
Also the color of mine is actually a Mercedes color. I dont know the paint code since the paint can is still in the car and I am not home anymore.
Road_Runner
Sep 2, 2024 04:46 PM
trackpack13gt
Oct 2, 2015 08:20 PM
CoyotePremium13
Sep 23, 2015 06:45 PM
