cams???
Old Jul 11, 2012 | 01:21 AM
ponyexpress82's Avatar
cams???
I have a 1982 Mustang 5.0 and i thinking about putting a new cam in it and im wondering what will work for that Mustang
Old Jul 11, 2012 | 02:58 PM
dcpirani's Avatar
If it still has the original engine in it, you will need a flat tappet cam. Compcams.com has a tool to help you pick out a cam and can even custom grind one for you.
Old Jul 11, 2012 | 07:11 PM
onebadvert's Avatar
i would not install a cam unless you are doing intake and heads. because the only thing you will gain is a cool lope. you will proabably even loose power.
Old Jul 11, 2012 | 10:01 PM
hi5.0's Avatar
^^^ +1 on doing heads, cam and intake as a total performance upgrade package. Might as well pick up a roller cam block if your engine uses the flat tappet type cam/lifters. That way you don't have to worry about flat tappet cam and lifter break in and probably better off the shelf grinds available.
Old Jul 23, 2012 | 06:29 PM
thanks for the information
Old Jul 23, 2012 | 06:41 PM
skunk21's Avatar
I'll help further. 1st check and make sure you have a 302 because some 4.2s did come with the '82 GTs. you can check the head casting #'s the 4.2 has E0SE-AB and the 302 has D9AE-AA in them. Teh 302 heads are pretty equal to the E7 heads on the later 302s also keep in mind that you do not have a roller cam or roller block.
to add some decent HP I would really, really think intake/carb and a cam. i then would add some headers and down the line think of running duals. Any good dual plane intake ie: Edelbrock performer/rpm and Weiand stealth come to mind.
Any good 570-600cfm carb with vacuum secondaries will be perfect for a mild motor. A 570-600 like I stated from Holley, edelbrock will be fine no need for anything fancy or expensive.
take a look at the edelbrock performer cam and also the rpm cam.
here is some specs on the rpm cam
http://www.jegs.com/i/Edelbrock/350/...arentProductId=
wallace
Mar 29, 2016 10:09 AM
14Glassback
Oct 4, 2015 08:52 AM
FromZto5
Sep 30, 2015 05:28 AM
Airborne42
Sep 24, 2015 10:27 AM
