Cam Questions
Old Apr 8, 2008 | 02:04 AM
future9er24's Avatar
Question Cam Questions
So for my birthday I received a $40 kragen gift card. I was looking around the site and I was debating buying a cam from Crane Cams
the problem is, I have no idea what to look for in a cam.
my II has a '92 302 with an edelbrock intake, 4bbl carb ad pretty free flowing exhaust save for the stock manfolds.
What kids of cam should I be getting? I really don't know what all the numbers translate into.
Here are the available cams in the $200 range
363902
Powermax Hydraulic Camshaft/Lifter Kit: RPM 1200-4800; Adv. Dur. 260 Int./272 Exh.; Valve Lift .456 Int./.484 Exh.; Lobe 112 Deg.; Includes Cam; Lifter; Shim Kit; Adjusting Nuts; Emission Code 1 Green; 50 State Legal
363932 Powermax Hydraulic Camshaft/Lifter Kit: RPM 1400-5200; Adv. Dur. 266 Int./274 Exh.; Valve Lift .456 Int./.472 Exh.; Lobe 114 Deg.; Includes Cam; Lifter; Shim Kit; Adjusting Nuts; Emission Code 3 Amber; Not Legal For Sale Or Use On Streets Or Highways
363942 Powermax Hydraulic Camshaft/Lifter Kit: RPM 1800-5400; Adv. Dur. 272 Int./284 Exh.; Valve Lift .484 Int./.512 Exh.; Lobe 112 Deg.; Includes Cam; Lifter; Shim Kit; Adjusting Nuts; Emission Code 1 Green; 50 State Legal
364802 Powermax Hydraulic Camshaft/Lifter Kit: RPM 2000-5000; Adv. Dur. 290 Int./Exh.; Valve Lift .484 Int./Exh.; Lobe 110 Deg; Includes Cam; Lifter; Rocker Arm Shim Kit; Emission Code 3 Amber; Not Legal For Sale Or Use On Streets Or Highways
Could someone with more experience with these engines tell me what's the best of the bunch?
Old Apr 8, 2008 | 08:32 AM
Redbaron93's Avatar
Arin, I like you am not real versed in cam technology but I have used the Ford Racing B cam and had really good results plus it sounds good at idle. The E cam offers a little more lift. Their F cam I believe is for supercharged cars and their X cam is their racing cam. Probably doesn't help you much. From the ones you have listed I would probably go with your last choice. Had a mechanic friend of mine tell me several years ago that the small block Ford likes duration around 290.
Old Apr 8, 2008 | 08:35 AM
Knight's Avatar
Needs to be more Astony
If they say not legal or street or highway use, you know its gotta be good!
Wish i knew more about cams to help. hope someone answers so i learn somthing.
Old Apr 8, 2008 | 10:10 AM
Grell's Avatar
What edelbrock intake do you have? Is it the performer, performer rpm, torker or other? Also is the stock cam a roller cam.Edelbrock has some really good matched cams for your intake. I have had a ton of both performer which is basically stock or a bit more and the rpm which on an engine set up right really works well. My lifted chevy truck had a performer rpm cam , intake and springs with tons of porting done to the heads and 489 cubes and 8.8 compression and was a really great power house for street. That was when it was stock hieght.
With the rpm range listed , I would try to pick one in the rpm range you drive in if you have a tach.Usually something like 1500-6000 is slightly hotter and still driveable. idle to 5000 rpm is more daily driver with good low end torque. If you have a roller cam go with one of fords roller cams but I am betting it isnt in 92.
Old Apr 8, 2008 | 12:30 PM
red pony's Avatar
363902
The answer to that question hinges on ( 1 ) what type trans is , stick or automatic , if auto, what stall-speed is the torque converter, ( 2 ) what rear gear you have ( 3.08 - 3.27 - 3.55 - etc ) , ( 3 ) what power-adders you plan to add down the road .
Old Apr 8, 2008 | 04:05 PM
The trans is a C4, and as far as I know its bone stock. It does chirp the tires into second if you're gunning it, but I don't know if thats how a stock C4 shifts or not... I don't know what stall speed the converter is either
My rear gear I'm pretty sure is a 3.00
There is a mild chance for a supercharger down the road. I have one that I don't know the history or background of that was used on a 2.9L ranger/bronco II. There is a chance I might try and sell that on ebay over the summer though.
As for my intake I'm pretty sure its a performer 289. And yes, it has the stock roller cam from 1992.
And Chris, I was right there with you in that train of thought last night before I decided to post this thread
wallace
Mar 29, 2016 10:09 AM
MustangConvert11
Sep 30, 2015 08:01 PM
