Caliper Pins/Bolts
I've been plagued with rattling calipers. The darn things clatter when going over cracks/bumps.I've had the car about 3 months now and it's driving me crazy (yeah, yeah...short trip). My manual (Clymer) doesnt indicate any insulator on the out-board half of the caliper, only the inside half. Locators are tight. I replaced the M/C because it was toast; leaking.
Front pads (ceramic) and rotors (slotted) were replaced shortly before I acquired the vehicle.
Questions are:
1. Do your calipers rattle? Is this a problem (chronic) with Foxes? (got a 68 mustang with 69 cougar disc set up on it that's tighter.)
2: Could my locating pins/bolts be worn? (stops fine, good pedal pressure)
3: I worry too much about such things?
Thanks in advance :worship:
Questions are:
Also get a set of SS bushings from Steeda or some other source.
And no you aren't worrying to much about things, It just doesn't engender security when your trying to haul your butt down from triple digit speeds and the front end feels like its trying to rattle off.
How do you know the calipers are causing the noise you hear?
Have you inspected the calipers to see if they are loose?
I can't imagine how this would be possible.
Originally posted by Coupe@August 6, 2004, 8:11 AM
Are these to replace the plastic sleeve?
Or is there something I'm missing? :scratch:
* I neglected to mention these are hex head locators.
Considering the PTT function of this board, I thought I'd bring the post up to speed :sleep: .
I went ahead and replaced the calipers and locators a few weekends ago. The locators/pins had probably 17 years worth of wear, as well as the calipers themselves. The rubber insulators were pretty much toast.
Chatter/rattle all gone now.
I decided to hold off on the stainless bushings/insulators from Steeda until I get a REAL order of parts to place.....
:worship: Thanks to all who helped troubleshoot.
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
