Brake problems on my '86!
OK, about ready to give up, I replaced the pads on the rear drums on my '86 GT because they were worn and were squeaking. I replaced the pads, the hardware and the wheel cylinder. The problem I am having now is the drivers side squeaks when I first apply the brakes, but when you press the pedal further down the squeak stops. But I can feel both rears grabbing and the drums gets real hot, plus you can smell the pads burning, and the pedal feels a bit mushy when they get hot. I have everything installed correctly and adjusted, like I mentioned above everything has been replaced in the back and the drums look good. Can this be caused by a bad distribution valve, master cylinder or hoses? That is the only thing other then the brake lines that have not been replaced. What would make the rears grab, what am I missing?
Have you checked the fluid and made sure the lines are clear? The fluid looks clear and not brown or dark?????
It is possible that your proportioning valve is stuck.....brake fluid should be changed at a minimum once every 2 years and should be clear. If your brake fluid is not clear, it is toast.....Brake fluid by nature absorbs moisture and that is created by the heating and cooling cycle they go through. If your fluid is dark or black then it is possible you have a stuck proportioning valve.
Originally Posted by svopaul
(Post 900393)
Originally Posted by palmaceae
(Post 900119)
the drums look good
(Post 900147)
It was dark, but bled them. But would old fluid cause this? |
(Post 900393)
Proportioning valve, that is the word I was looking for, not distrubution valve! This was the next thing I was going to replace, because it makes the most sense. BTW, are new proportioning valve available at local auto parts stores? |
Originally Posted by Puter
(Post 900443)
You did not turn them?
Dark fluid is bad for all components, Dirt and Moisture like Paul said carries rusty crap all through your brake sysytem...
(Post 900587)
(Post 900951)
No, they are not. Your best bet is to take it apart and clean it. There are O-rings in there and it can be rebuilt. Sludge build up from lack of fluid changes can cause it to seize up.
Take it apart and see how the O-rings are...you may be able to reuse them if not hard and brittle or you can carry them to your local auto parts store and choose from their selection of O-rings. Worst case you can buy an O-ring assortment kit from Harbor Freight or Northern Tools.
(Post 901022)
I do not look forward to taking the lines off the block, they look a little corroded on the outside (where the nut joins the line, turn the nut the line moves with it), hopefully a shot of WD-40 will loosen them up. |
(Post 901053)
Thanks!
(Post 900393)
Just to let you know you were right! The valve was stuck and quite dirty when I opened it up. I cleaned it first but still had the problem (while bleeding the rear brakes, no fluid would flow when pumping the pedal) but took it apart again and made sure nothing was sticking, now all works well. I would still like to replace it if I could find one! Thanks again! |
(Post 910795)
Thanks again! |
