? On 5 Lug Swap
Old Jan 5, 2012 | 05:33 PM
SleepingStang's Avatar
? On 5 Lug Swap
Ladies and Gentlemen,
I am in the process of converting to 5 lug using 95 GT parts. GT calipers front and rear, spindles, etc. Question is what MC to use? I plan on using my stock booster and know that the options in MC's can change pedal feel and brake performance. Anyone out there running the same setup and how is the pedal feel? Thanks.
Old Jan 5, 2012 | 06:54 PM
don't really have an answer to your question I just wanted to welcome you to TMS, Can you just use the one from the 95?
Old Jan 5, 2012 | 07:05 PM
I bought a 93 Cobra master cylinder to go on my stock brake booster. I haven't done the swap yet but that's the advice I was given by someone who had tried several options already.
For the record I'm using 99 GT brakes (pbr's) with 94 spindles of course, and in the rear I got the Northern race cars setup because it keeps the correct track for the foxes with the fox length axles.
Keeping those back tires from sticking out 1/2" further than they should.
Old Jan 5, 2012 | 08:32 PM
Thanks Glenn and 2k. Glenn I assume that I could use the 95 MC but some of the tech articles that I have read you need to match the MC bore size to the booster to the overall area occupied within the calipers. This is one of the tech articles I am referring to.
http://www.stangnet.com/mustang-foru...thread.801400/
I'll have to do some more research before I dive into that decision. I guess the best thing is that the MC is not that expensive of a part.
2k, I as well will be using the North Racecars axle and bracket kit. Looks to be a real quality piece.
Old Jan 5, 2012 | 09:10 PM
I wish I had it on the car. Good news is I was going to put them on a 91 Vert I bought a couple of years ago, but since then I've bought a 93 Notch that will be getting this setup and the Vert will go bye bye.
I really need to get this stuff in the car. I've had it for a while but I just keep driving the car and I don't want it down for a week while I find time to work on it.
Old Jan 5, 2012 | 10:54 PM
Fortunately and unfortunately I don't have that issue in Wisconsin. My car goes stationary upon forecasting first salt throwing weather and comes out after the first good rain that washes the salt away.
Old Jan 6, 2012 | 03:51 AM
AlsCobra's Avatar
A Man Just Needs Some....
I wouldn't be very concerned with the booster. Master maybe and possibly the proportioning valve. I've seen it done with just caliper changes and nothing else. What brake set up are you planning for the rear?
Old Jan 6, 2012 | 06:49 AM
skunk21's Avatar
Here is the Tech article on 5-lug swap/ brake upgrades I swear by and has been used by many people I know and parts of it have been used in other sites tech sections but I'll give you the link to the whole thing.
1st I'll post the section on MC ( and yes you have to swap the booster you will get much better brake feel..ie mushy otherwise)
this is from the tech article..
Master Cylinder Upgrades:
The stock master cylinders on the 87-93 Mustangs are marginal with just the install of larger front 73 calipers. The 3 port design is really to blame with the small 21mm bore. If you swap to rear disc, then a new MC is needed! There are 4 common MC upgrades out there for the Mustangs: the Lincoln/SVO unit, the '94-98 V6 unit, the '93 Cobra unit and the '94-95 Cobra units. Each is a 2 port MC, so a conversion will be needed but they are all different bore sizes. Which one is the correct unit for you? Read on:
Here is a more specific information on the master cylinders mentioned:
'84-86 SVO - (SAE Threads) 1 1/8" bore, old style aluminum reservoir unit. no low fluid sensor. This is the same as the 84-90 Lincoln Mark 7. The difference is usually the SVO is aluminum, and the Lincoln can be a cast iron unit. The aluminum is what you want to keep the weight down.
'85 Towncar - (SAE Threads) 1" bore, old style aluminum reservoir unit. no low fluid sensor.
'93 Cobra - (metric threads) 1.00" bore
'94-95 GT/V6 - (metric threads) 1 1/16" bore, stock plug in for the low fluid sensor
'94-98 V6 - (metric threads) 1 1/16" bore, stock plug in for the low fluid sensor
'94-95 Cobra - (metric threads) 15/16" bore, stock plug in for low fluid sensor. Ports are reversed thread sizes from 87-95 LX/V6/GT
'99 V6 - (metric threads) 1.000" and 1.006" bore. Can be converted to work for the low fluid sensor on the fox3 cars
96+ V8 Units - These are hydroboosted and the mounted flange is vertically vs horizontal required for a vacuum booster. They will NOT work
Low fluid sensor notes: The stock '87-93 master cylinder has a plastic reservoir with a low fluid indicator. The '93 Cobra and the '94-98 units all have this, but the SVO unit does not have this feature. You will lose the low fluid sensor if you use the SVO unit. This will not cause the dash light to stay on, just permanently off. For the E-Brake light on the dash to come on with the E-Brake, you need to make a jumper in the connection you just removed. Connect pins 2-3 (the 2 purple wires, not the black ground). Be sure to label the connection to know what it is for in the future. For the '93 Cobra and '94-98 units, it is a direct plug in.
Which Master Cylinder?:
87-93s: The 87+ mustangs all use metric threads on the master cylinders. They are 3 port units, thus you must convert to a 2 port setup to use any upgraded master cylinder.
3-2 Port Conversion Products
The SVO unit was a very popular swap until the '94-98 units came readily available. It is very inexpensive at $15 rebuilt, has a large bore, but requires adapting to SAE threads and you lose your low fluid sensor. Do NOT use this unit unless you have the SVO front 73mm brakes and rear SVO brakes
The best all around unit is the '93 Cobra with the 1" bore, but it is more rare and it cost more. Its bore size is about ideal for most any brake setup out there presently. This is the unit I would recommend from most all brake swaps!
The '94-98 V6/GT MCs would be good compromise for most everything with the addition of a 94+ V6 brake booster or use of the larger 99+ GT/V6 PBR front calipers. You can find these for about $25 used at yards with the reservoir included.
If you are planning on running the Cobra or Brembo brakes, then I would suggest the '93 Cobra or '94-95 Cobra 15/16" MC with the stock booster. This will give you a pedal that is not to hard.
The last consideration is the cam in the engine. I make my recommendations off a stock 87-95 cam. If you are running a larger cam with less vacuum at idle, either drop a size in the master cylinder bore or set up to the larger 94-95 brake boosters to compensate. If the pedal is to firm after the master cylinder swap, then swap in the larger 94+ V6 vaccum brake boosters. Any of the 94-95s and 94+ V6 units will work. They are all larger than the stock 87-93 V8 unit, thus will give you more assist. I would not suggest trying to find the largest Sn95 booster available since they are all larger than the stock unit you are replacing - but finding the most cost effective unit.
79-86s: Since you already have a 2 port SAE threaded MC, you can swap one from a different car. The '85 Lincoln Towncar with a 1" bore is about the best unit for most all brake upgrades.
Which Master Cylinder to use on fox3 ('87-93) cars with SN95 brake parts:
Well since you are using the Sn95 parts, you should use a SN95 master cylinder as they are designed together from the factory. Either the 1" 93 Cobra unit or the '94-98 V6 master cylinder will bolt directly into the PV to MC fittings that you have! You just need to convert the stock 3 port setup to a 2 port one . You can do this with fittings under the proportioning valve to keep things clean! The low fluid sensor is even a direct plug in!
If you use the '94-95 Cobra master cylinder for a softer pedal feel, you will need to get 2 fittings to swap the lines on the master cylinder. The cobra has fittings that are the opposite of the v6/GTs so they did not get mixed up on the assembly line.
Now you need to convert the stock 3 port MC to the newer 2 port MC design. You can either purchase a 93 Cobra combination valve from Ford for about $60, or use a 3-2 port conversion kit. The 3-2 kits is a T fitting that screws into the bottom of the PV and has an adapter for the 3rd port! It will work with the the '94-95 GT/V6, '94-98 V6 MC, the '99 V6 units, the '94-95 Cobra, and '93 Cobra MCs! No Cut, No Flare! 3-2 Port Conversion Products
The other option is to use the parts from a '94-present NON-ABS mustang or '79-86 Mustang. They have a large fitting and special nut that will screw into the back of the stock combination valve. You will have to cut your stock 3rd port line and double flare the brake line there. Be sure to not remove any of the shuttle valve parts in the rear of the combination valve if you go this route.
Master Cylinder Notes:
The '96 and newer V8 Mustangs use a Hydroboosted master cylinder. The mounting flanges are vertical vs. the horizontal flanges required on the vacuum boosted units. Thus they are not compatible with vacuum boosters in the earlier mustangs!
Proportioning valve modifications:
The stock proportioning valve will need to be modified if you go to rear disc or to install an adjustable proportioning valve. You will need the FMS part: M-2450-A and an adjustable proportioning valve to complete the modification. The stock PV is housed in the front part of the combination block. This block is under the master cylinder and houses the PV and shuttle valve or pressure differential valve.
Why do you need to modify the valve? Because it is designed for the specific car and brakes that come with it off the assembly line. So if you change to different size brakes, you will need to change the front to rear bias via the proportioning valve. If you do not, then you will not get the most braking capability out of the car. Worst case scenario, you have too much rear bias and the car spins around when the brakes are applied. Not good on a rainy night!
If you have a Sn95 PV, why not use that? For the same reason you are not using your stock PV. It is not setup correctly for the amount of bias you need. The Sn95 valves are setup for the Sn95 car's weight, braking system and bias requirements. If you do find a 94+ car without ABS or 79-86 , you will notice that they are setup for a 2 port master cylinder. You can swap the end nuts on the combination valve and use this fitting as long as you cut and flare the nut from the donor car to make a factory like 3-2 conversion! You will not find those size of brake nuts at any parts store! Alternatively, you can remove the front internals and cap and transfer that to the fox3 combination valve and that will work to the Sn95 bias specs. This may not be the best bias for a fox3 car, but will work. The solution is to defeat the stock PV by gutting the unit and running an adjustable valve.
Okay, so how do you "gut" this proportioning valve? You use a 13/16 wrench and take the front cap off of it. Be careful as once it is loosened, the spring will shoot it out! Then remove the spring, the spring seat and rod. You may need some needle nose pliers to remove the rod from the valve. Do NOT remove the rear spring and rod from the rear of the valve. If you do modify the rear of the valve to work like the FMS M2300K kit or tap the rear for the 3rd port, be sure to install the rod and spring back in there!
Once you are done modifying the stock valve, you need to install an adjustable unit. There are two kinds of adjustable units: **** style and lever style. The lever style is more designed for an in-car application so that you can adjust the bias as the tires and brakes wear down in a race. You want the **** style. To install it, remove the coupler along the passenger side firewall and replace that with the valve. [pic]
When you bleed the brakes, adjust the valve all the way in for the maximum rear pressure. Once done, adjust the valve all the way out, and then in 4 full turns for your initial setting. Adjust in 1 turn increments from there and then half turn increments to fine tune. You will feel the braking and the pedal differ as the bias is changed.
Brake Booster Upgrades:
Once you have the larger master cylinder on your Mustang, you may find that it takes more pressure on the pedal to lock up the brakes then you would like. First, check all the vacuum lines for dry rot, cracks or holes. Replace all hoses that look skeptical. This will restore the vacuum for the booster to work properly.
If that still does not help, then you can consider two options. The first being to change to a smaller master cylinder. The second it to upgrade the brake booster. Any of the 94-95s and 94+ V6 units will work. They are all larger than the stock 87-93 V8 unit, thus will give you more assist. I would not suggest trying to find the largest Sn95 booster out there as any are larger than the stock unit you are replacing. If you have heard about the Cobra brake booster, the same unit in the Ford M2300K brake kit (same as 1994-1998 Mustang Cobra and 1993 & 1995 Cobra R), you probably have heard horror stories about installing the unit. You do NOT need to beat the strut tower to install this unit for most all 87-93 installations. Remove the old unit and the lower hole in the firewall you need to elongate down about 1". This will allow the unit to slide right in!
Cost $100-200 depending on if it is reman or new. You may be able to find one from a person selling it from their M2300K kit for cheaper.
here is the link...http://home.comcast.net/~mjbobbitt/mustang/page11.html
5 lug swap link for front..
http://home.comcast.net/~mjbobbitt/mustang/page7.html
Rear swap..
http://home.comcast.net/~mjbobbitt/mustang/page8.html
whole entire article..
http://home.comcast.net/~mjbobbitt/mustang/page1.html
best of luck
Old Jan 6, 2012 | 07:00 AM
AlsCobra's Avatar
I vote for Skunk21 to be the fox body section moderator. Dudes got all the fox info we need here.
Old Jan 6, 2012 | 08:25 AM
skunk21's Avatar
Thanks man. I'm working on tech stuff like 4 cyl swap, T5 swap, etc. I'm not sure who to contact so I can make stickies and set up how to articles on stuff.
Old Jan 6, 2012 | 08:28 AM
AlsCobra's Avatar
Pm Scothew about it.
Old Jan 6, 2012 | 08:44 AM
skunk21's Avatar
I'll do that now I just pmed robb m. but I'll try him also. Thanks.
Old Jan 6, 2012 | 08:58 AM
If you need I can sticky whatever you want and clean up any clutter that people may post while you are working on it
Old Jan 6, 2012 | 08:59 AM
We really need to revive the Fox section of this forum
Old Jan 6, 2012 | 09:17 AM
skunk21's Avatar
Thanks. I just got a PM for scothew also in thsi but I'll contact you also. I'm trying to work up a nice tech section or sticky with some good stuff but I have tons of info so it is going to take me alot of work to get it done. Your help keeping it clean will be perfect so it doesn't get outta hand and cluttered but yes I agree we need to kick this section back to life. I'll be the fox body guru . I would also like to do a seperate section on production information and other non-tech stuff more like history of teh car, got tons of that also.
Old Jan 6, 2012 | 01:16 PM
Thanks Skunk for the great info.
Old Jan 6, 2012 | 01:52 PM
skunk21's Avatar
Happy to help.
Old Jan 8, 2012 | 01:51 AM
Still in process of deciding on booster, MC, and calipers. I would like this to be a fairly problem free install. I have read that my 92 booster should be fine as long as I match up the correct MC, then others state that the booster should be changed. Question at this point being will the 93 Cobra booster fit without banging up the shock towers? I do not like drilling holes in my car so you know where I am coming from here. I assume the Cobra will slide right in as the shock towers and such were not changed from 92 to 93 that I am aware of, even for the Cobra. Any insight or knowledge either way?
Old Jan 8, 2012 | 07:09 AM
skunk21's Avatar
'93 Cobra booster/MC are a dop in and sn95 swap. what are you doing for the rears? yes there ar plenty who haven't changed the booster, does it make it a correct install you decide. The ford racing 5-lug dics brake conversion kit ( M-2300-K ) came with a cobra brake booster. I haven't done this yet myself but for sure I know how I'm doing it. Hey I know guys who swear you can you change front spring with hose clamps and a jack and started a 12 page argument over it, there are many ways to do things but...
Old Jan 8, 2012 | 12:35 PM
Skunk I am thinking of the 93 cobra booster and the 94 and up cobra calipers up front and in rear. St
