Transmission '65
Old May 18, 2013 | 02:13 PM
Juggalo586's Avatar
Alternator tested good. Any other ideas what could have caused a car to shut off?
Old May 18, 2013 | 05:28 PM
stangs&thangs's Avatar
I just had this happen on my 68 fast back and here is a list of everything I check or replaced. Mine just so happened to be a couple of things
Starter
Alternator
Ignition switch
Solenoid
Fuses
Battery terminals clamped tight
Wire from battery to grounding bolt
Wire from battery to solenoid
Both wires from solenoid to starter and ignition switch
Old May 19, 2013 | 06:54 AM
Juggalo586's Avatar
Awesome. I appreciate that list very much. I'll make sure I check all of those things.
Old May 19, 2013 | 10:23 AM
No problem. So before I help you try and diagnose it, have you tried jumping the solenoid? If you don't know what I mean, let me know and ill walk you through it or you can google it. It's a very easy thing to do, all you need is a screw driver but let me know
Old May 19, 2013 | 11:14 AM
Juggalo586's Avatar
I did try jumping it. Turned out the starter wasn't engaging the flex plate? And it needed a new regulator. Thanks for the help guys. I think the tow truck guy was wrong about the fluid in my original post.
Old May 19, 2013 | 01:59 PM
No problem. Let us know once its running again
Old May 19, 2013 | 04:56 PM
Juggalo586's Avatar
It is up and running again with no mechanical issues for now.
Now I just need to get the headlights working. Any ideas how to test the switch? Or should I just buy a new one and hope that works.
Old May 19, 2013 | 07:21 PM
matcox83's Avatar
Start a new thread for the headlights and make sure you have a 12V test light!
Old May 19, 2013 | 07:29 PM
Glad to know another mustang is back on the road. Congrats
CiniZter
25
Apr 28, 2016 05:41 PM
Rando
Sep 30, 2015 12:28 PM
Mustang65bob
Sep 21, 2015 11:30 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
