trans swap
Heres a list of most of the parts you will need for the swap (if I missed anything Im sure someone will chime in):
C-4 for V-8 with floorshift
torque convertor
floorshifter assembly
shift lever-trans to shifter
neutral safety start switch
accelerator pedal linkage with kickdown lever
kick down cable
block to transmission spacer plate
flywheel
flywheel bolts
starter snout
remove pilot bushing from end of crankshaft
transmission cooler lines
vacuum modulator line and hoses
radiator with transmission cooler, or aftermarket cooler
case of ATF
auto brake pedal
torque convertor
kick down cable
flywheel
flywheel bolts
starter snout
case of ATF
auto brake pedal
