Timing
Old May 9, 2012 | 02:43 PM
les's Avatar
les
Timing
Forgive my noviceness. When using the light gun on the mustang 289 is the mark I am shooting for the 6 left or right of tdc
Old May 9, 2012 | 07:08 PM
houtex's Avatar
Assuming a normal motor, and not a marine one that runs backwards, as you face the engine from the front of the car, the engine turns clockwise.
So, if TDC were to be directly on the top of the crank pulley, 6 degrees BTDC is on the right of that mark, in the direction of the crank turning.
I'll say "right," but, it's really a perspective thing. It's more "in the direction of the crank's turning., which could be down, or up, or left, even, depending on how you're looking at it.
/Not sure I just confused you... I'm so sorry. Go with 'in the direction of the crank turning.' and that will always be correct, on any motor.
red pony's Avatar
One side of the harmonic damper is marked clear up to 30 degrees before top dead center. The other side of "0" is after top dead center and usually only goes to 10 degrees after top dead center. Set your timing to 10 degrees BTDC even if it calls for 6 degrees BTDC. It will run fine there.
Jim74656
May 1, 2023 02:15 AM
Feffman
Aug 22, 2015 06:27 AM
Feffman
Midwest
Aug 15, 2015 08:08 AM
roushcollection
Jul 28, 2015 02:08 PM
Sacmus
Jul 22, 2015 02:59 AM
