Swapping 200ci I6 for 302 V8
Old Jun 8, 2013 | 04:37 PM
Juggalo586's Avatar
Currently I have a 200ci I6 in my 65 Mustang, I'm looking to swap it for a 302. Does anyone have any idea what all I will have to switch out in the process?
Old Jun 8, 2013 | 08:24 PM
stangs&thangs's Avatar
Motor mounts and v8 spindles are a definite switch
Old Jun 8, 2013 | 09:10 PM
matcox83's Avatar
I will forget something I'm sure.
V8 suspension, front and rear including spindles and axle and all steering components.
Motor mounts, radiator, driveshaft, gas pedal, exhaust.
5 lug wheels, probably new tires.
Fuel line on a V8 runs outside the frame rail to clear the exhaust.
If you get everything from a donor car, count on replacing all brake components and most likely all bushings in the suspension and steering.
Lastly, make sure your car is in better shape than the donor.
You can cut corners but you shouldn't.
Ray11
Sep 25, 2015 12:43 PM
Grabber5.00
Sep 13, 2015 06:53 AM
