Stumble
Old May 21, 2012 | 09:40 AM
les's Avatar
les
Stumble
Have a 66 with the 289 and auto lite 2100. The problem I am having is she has a stumble on accel I with push the gas and she takes off for a second then stumbles then it catches it self and takes off. I have replaced plugs wires cap rotor coil points condenser fuel pump fuel filter sending unit and rebuilt the carb. And the battery is new I am at a loss
Old May 21, 2012 | 09:51 AM
Kinyodas's Avatar
I'm thinking check yer vacuum - check the lines & the tree - seal off everything but the motor, if necessary.
Old May 21, 2012 | 09:55 AM
Did it happen after rebuilding carb? Accelerator pump spraying properly?
Old May 21, 2012 | 10:05 AM
AlsCobra's Avatar
A Man Just Needs Some....
Think the bowl could be overflowing and dumping on acceleration? Not too familiar with that carb.
Old May 21, 2012 | 10:09 AM
Don't know for sure about that.
My truck would stumble as you went from idle jet to main jet when the accelerator pump seal was shot. The spray in the throat compensates for the fuel need and jet transition.
Old May 21, 2012 | 10:15 AM
AlsCobra's Avatar
It definitely sounds like carb issues for sure. Not my specialty though. F.I. man myself.
Old May 21, 2012 | 10:20 AM
F.I. man myself.
I'm trying to learn that. I want a Kaase style FI w/stacks intake!!
Old May 21, 2012 | 10:26 AM
AlsCobra's Avatar
Ouch! That's automotive art right there.
Old May 21, 2012 | 02:18 PM
drumr90's Avatar
I have that exact carb im pretty shure from memory. Replaced it with bigger 4 barrel edelbrock and didnt have the problem again.
Old May 21, 2012 | 11:51 PM
les's Avatar
les
The accel pump was replaced in the rebuild it has done this since I have owned her. It looks and sounds like the pump is shooting enough fuel into the carb. Float bowl was set 3/4 deep as per spec. Vacuum leak I am not sure of sealed the carb to spacer and spacer to body mount. Replaced the dizzy advance to carb hose. Where is the other vacuum? It has very little in the effect of hoses in the engine bay thank god.
Old May 21, 2012 | 11:53 PM
les's Avatar
les
Oh ya I rebuilt it because it sat since 95 and had orange jello in the fuel bowl which I am guessing was once gasoline. New accel pump new power valve new pcv valve haven't replaced that hose yet
Old May 22, 2012 | 05:14 AM
drumr90's Avatar
Ok easy way to check vacume leak. Take a can of wd40 and spray around all the houses. Thats how i found leaks in myn.
50Cal
Sep 16, 2015 03:54 PM
bob
Aug 15, 2015 08:58 AM
tdf017
Aug 5, 2015 10:13 AM
