Paint Guys...Help!
Old Mar 10, 2005 | 03:14 PM
19mustang65's Avatar
we painted my car recently with a bc/cc paint. when we sprayed the clear the temp of the room was rappidly going from 75 degrees down to a much colder temp(outside temp was 0, we had heaters that were turned off to spray, but temp droped fast) this caused an orange peel type of finish. we made the mistake :bang: of only putting 3 coats of clear so we cant sand enough of to make it smooth without worrying about hitting the metallic base. ive already waxed it twice. would it be possible to somehow clean all the wax off and rough up the clear a lil then apply more layers? any suggestions please. thanks
Old Mar 10, 2005 | 03:21 PM
Stroked66's Avatar
Sure!
Just clean it real well with wax/grease remover a couple times (DP330 is good stuff), then sand it with 1500 and re-clean, then shoot a couple more coats of clear!
Old Mar 10, 2005 | 03:53 PM
u sound pretty certian about that. u think it will turn out ok and not screw up whats already there?
Old Mar 10, 2005 | 04:51 PM
Coupe's Avatar
What have you got to loose?
Like he said, scuff.....wipe with wax/degreaser......shoot some more clear
Old Mar 10, 2005 | 05:10 PM
sombody had suggested dawn dish soap to clean the wax off?
Old Mar 10, 2005 | 10:01 PM
copasspupil's Avatar
Stroked is exactly right. It will clean it better than soap and water. You don't want to feel like you screwed it up again.
Old Mar 11, 2005 | 07:53 AM
390 4spd's Avatar
You should NOT wax a car untill you are pleased with the finish.The wax fills the micro pits in the paint . Sand it down with some 2000......stay off the edges.......3 coats should be more than enough to sand with out getting into base....if you can't get it smooth after sanding , the clean all surfaces very good and apply another coat or two of clear...
May 3, 2026 05:42 AM
robjh22
Dec 14, 2015 08:41 AM
Cobiecane
Oct 23, 2015 08:44 AM
GLOCKer
Sep 28, 2015 05:20 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
